Moving to the ASK the Community forum per suggestion.
aI am the Coach and programming mentor for Thunderstorm Robotics from Payne County Oklahoma, Heartland Trails BEST Hub. Game day is less than 2 weeks away. We don’t even have an actual connection for the digital inputs yet to read in so I haven’t tested the code. I just worked it up this weekend. I have programmed a very little in VB and tried to learn basics of C/C++ and Java. Just getting values of 3 digital inputs and comparing to a table of 8 possible combinations and then sending that back to a switch case to provide some kind of visual output depending on the unsigned char that’s returned.
I have the code that follows setup to read in three digital inputs (set as global unsigned chars) in a user function and then it runs through the possibilities and returns an unsigned char back to the main routine. First, am I setting the conditions correctly in the If’s? Also, would this be better set as a switch case??? And if so, then how to implement the multiple variables in the Switch statement.
Also, all variables are default to = 1 so that the last result is true and kicks out of the user function back to main.
#include "Main.h"
unsigned char Func_DataPort ( void )
{ // runs the routine to retrieve data port assignments and create a variable with the results
unsigned char Port_Set = 1;
CHAR_PG2 = GetDigitalInput ( 1 ) ;
CHAR_PG1 = GetDigitalInput ( 2 ) ;
CHAR_PG0 = GetDigitalInput ( 3 ) ;
if ( CHAR_PG2 == 0 & CHAR_PG1 == 1 & CHAR_PG0 == 1 )
Port_Set = 2 ;
return Port_Set ;
else if ( CHAR_PG2 == 1 & CHAR_PG1 == 1 & CHAR_PG0 == 0 )
Port_Set = 3 ;
return Port_Set ;
else if ( CHAR_PG2 == 1 & CHAR_PG1 == 0 & CHAR_PG0 == 1 )
Port_Set = 4 ;
return Port_Set ;
else if ( CHAR_PG2 == 1 & CHAR_PG1 == 0 & CHAR_PG0 == 0 )
Port_Set = 5 ;
return Port_Set ;
else if ( CHAR_PG2 == 0 & CHAR_PG1 == 1 & CHAR_PG0 == 0 )
Port_Set = 6 ;
return Port_Set ;
else if ( CHAR_PG2 == 0 & CHAR_PG1 == 0 & CHAR_PG0 == 1 )
Port_Set = 7 ;
return Port_Set ;
else if ( CHAR_PG2 == 0 & CHAR_PG1 == 0 & CHAR_PG0 == 0 )
Port_Set = 8 ;
return Port_Set ;
else if ( CHAR_PG2 == 1 & CHAR_PG1 == 1 & CHAR_PG0 == 1 )
Port_Set = 1 ;
return Port_Set ;
Thanks for your answers.
