Recreating Simon with VEX
I am trying to recreate the game Simon using Vex products. I have all of it built, but I cannot figure out why my code does not do what is expected. The code is below.
#pragma config(Sensor, dgtl1,  yellowButton,         sensorTouch)
#pragma config(Sensor, dgtl2,  blueButton,        sensorTouch)
#pragma config(Sensor, dgtl3,  greenButton,        sensorTouch)
#pragma config(Sensor, dgtl4,  redButton,        sensorTouch)
#pragma config(Sensor, dgtl5,  yellowLed,         sensorLEDtoVCC)
#pragma config(Sensor, dgtl10, greenLed,          sensorLEDtoVCC)
#pragma config(Sensor, dgtl11, redLed,            sensorLEDtoVCC)
#pragma config(Sensor, dgtl12, blueLed,           sensorLEDtoVCC)
void clearLCD() { // Celar the LCD Screen
	clearLCDLine(0);
	clearLCDLine(1);
int buttons; // This is used to detect which button(s) are pressed
bool buttonPressed = false; // This variable is to control when the loop stops running
bool correctButton = false; // This variable is to tell if the game should continue
void waitForButton(tSensors correctButtonToPress) { // Function to wait for a button
	buttonPressed = false; // Make sure that all variables are setup correctly
	correctButton = false; // "
	clearTimer(T1);	// This is also used for controlling when the loop stops running
	while (!buttonPressed && time1[T1] < 2000) { // This loop is used to wait for button presses.
		buttons = (SensorValue[redButton] << 3)+(SensorValue[greenButton] << 2)+(SensorValue[blueButton] << 1)+SensorValue[yellowButton]; // Sets the buttons variable to whatever button
        // is pressed (RED = 8, GREEN = 4, BLUE = 2, YELLOW = 1)
        // (0 if no button is pressed)
		if (buttons > 0) { // If there is a button pressed
			buttonPressed = true;  // Tell the game that a button has been pressed
			switch (buttons) {	// Check which button was pressed
				case 8: // If the red button was pressed ...
					if (correctButtonToPress == redButton) { // If the RED button is the button we want, tell the game that the player got it right
						correctButton = true;
						SensorValue[redLed] = false;
						playTone(450, 50);
						SensorValue[redLed] = true;
					} else {																	 // Otherwise, thell the game that the player was wrong
				case 4: // If the green button was pressed...
					if (correctButtonToPress == greenButton) { // If the GREEN button is the button we want, tell the game that the player got it right
						SensorValue[greenLed] = false;
						playTone(560, 50);
						SensorValue[greenLed] = true;
				case 2: // If the blue button was pressed...
					if (correctButtonToPress == blueButton) { // If the BLUE button is the button we want, tell the game that the player got it right
						SensorValue[blueLed] = false;
						playTone(650, 50);
						SensorValue[blueLed] = true;
				case 1: // If the yellow button was pressed...
					if (correctButtonToPress == yellowButton){ // If the YELLOW button is the button we want, tell the game that the player got it right
						SensorValue[yellowLed] = false;
						playTone(525, 50);
						SensorValue[yellowLed] = true;
				default: // If a combination of buttons was pressed, end the game
					break;
void playVictorySong() // Victory Theme
// All this does is play a tune.  I doubt this would cause the problem.
bool shouldContinue = true;
task main()
	wait1Msec(2000);
	char sequence[50]; // This character array is a list of letters that holds the sequence.
	for (int i = 0; i < 50; i++) { // This loop just sets the sequence to blank
		sequence* = ' ';
	for (int i = 0; i < 50; i++) { // This loop controls the logic of the game.
		if (!shouldContinue) { // If the game should not continue, display "Game Over", and a point count
			displayLCDCenteredString(0, "Game Over!");
			int points = i-1;
			string pointsString; // To hold the string for displaying the number of points
			sprintf(pointsString, "Points: %d", points); // Creates a string with the point count in it
			displayLCDCenteredString(1, pointsString); // Display the point count
			playTone(9000, 50);
			break;
		int next = random[3];		// This generates a random number between 0 and 3.
		switch (next) {	//This just checks what the number is, and sets the colro at the current position in the sequence.
			case 0:							// if the number is zero, set this position to RED
				sequence* = 'R';
			case 1:							// if the number is one, set this position to GREEN
				sequence* = 'G';
			case 2:							// if the number is two, set this position to BLUE
				sequence* = 'B';
			case 3:							// if the number is three, set this position to YELLOW
				sequence* = 'Y';
			default:						// if somehow the number is not one of these, don't do anything
				break;
		for (int j = 0; j < 50; j++) { // This loop displays the sequence using beeps from the speaker, as well as lighing up the LEDs.
			switch (sequence[j]) { // This checks which color, then lights us the correct LED and plays the correct sound.
				case 'R':									// If the color is RED, Turn on the Red LED, play a sound, then turn off the LED
					playTone(450, 50);
				case 'G':									// If the color is GREEN, Turn on the Green LED, play a sound, then turn off the LED
					playTone(560, 50);
				case 'B':									// If the color is BLUE, Turn on the Blue LED, play a sound, then turn off the LED
					playTone(650, 50);
				case 'Y':									// If the color is YELLOW, Turn on the Yellow LED, play a sound, then turn off the LED
					playTone(525, 50);
				default:									// If the color is somehow not any of the others, do nothing.
					break;
		// The next part is the most complicated. It has to check that the player is inputing the correct series of buttons.
		for (int j = 0; j < 50; j++) { // This loop waits for a button to be pressed, then either continues or ends the game depending on the button
			char next = sequence[j]; // This is just to make checking which button needs to be pressed easier
			if (next=='R') { // If the red button is next in the sequence wait for a button to be pressed, then check if it was the red button
				waitForButton(redButton);
			} else if (next=='G') { // If the green button is next in the sequence wait for a button to be pressed, then check if it was the red button
				waitForButton(greenButton);
			} else if (next=='B') { // If the blue button is next in the sequence wait for a button to be pressed, then check if it was the red button
				waitForButton(blueButton);
			} else if (next=='Y') { // If the yellow button is next in the sequence wait for a button to be pressed, then check if it was the red button
				waitForButton(yellowButton);
			if (!correctButton){				// If the wrong button was pressed, tell the game to display "Game Over"
				shouldContinue = false;
				break;
	if (shouldContinue) { // If the game is over, and the player succeded, tell them they won and play a victory song
		clearLCD();	// Clear the LCD
		displayLCDCenteredString(0, "You Win!"); // Display "You Win!" on the LCD
		playVictorySong();   // Play a Victory Song
If you would like a picture of the bot itself, let me know. But for some reason, the code, as I said, does not behave as expected. It is supposed to generate a random sequence, one at a time, like the game Simon, and display it to the user. For some reason, the LEDs turn on, but they wont turn off, and then the sounds are all messed up. The sound plays normally for the first button, then you press the button, and the sound plays too long, then the loss tone plays. Not sure what is wrong.
Any help is appreciated. Thanks in advance!*****
I don’t have time to go through all of that and I haven’t used the LEDs and don’t code in RobotC, but here are two quick things:
  1. Where is the LED plugged in? As in, which two of the three holes are you using? In this thread ( https://vexforum.com/t/question-on-programming-led-indicators-using-robot-c/20044/1 ) the OP had a similar problem, and the wires were in the wrong holes.
  2. As a general rule you don’t want to assign a fixed length to something that could be arbitrarily long. It would be better to use pointers to dynamically increase the size of the array (which is really replacing it and throwing out the original). Then in your for loops you go until the last item instead of always going to 50. But 50 is small enough that the Cortex should be able to get through the wasted processing quickly, and at the same time 50 is big enough that it’s unlikely anyone will get further. So you should be safe.
