I am currently chanign my control scheme to support mutiple drivers. My Controls are split up into two classes and two files. A header file called “ControlScheme.h” and an implementation file called “ControlScheme.cpp”. Below are those files.
ControlScheme.h
class ControllerInteraction {
public:
static void moveLeftSide();
static void moveRightSide();
static void pullIntake();
static void pushIntake();
static void liftArm();
static void lowerArm();
static void extendPiston();
static void retractPiston();
static void stopIntake();
static void stopArm();
static void stopPiston();
class Driver {
bool running = false;
static void nothing();
public:
static void setDriverCieran();
static void setDriverCharlie();
static void setDriverAndrew();
ControlScheme.cpp
#include "vex.h"
// this comment is here because they auto format formats include lines by
// alphabetical order which ■■■■■ up some dependancies
#include "ControlScheme.h"
void ControllerInteraction::moveLeftSide() {
LeftMotors.spin(fwd, Controller.Axis3.position(pct), pct);
void ControllerInteraction::moveRightSide() {
RightMotors.spin(fwd, Controller.Axis2.position(pct), pct);
void ControllerInteraction::pushIntake() {
// Intake Motor fwd 50% power
IntakeMotors.spin(fwd, 50, pct);
void ControllerInteraction::pullIntake() {
// Intake Motor rev 50% power
IntakeMotors.spin(reverse, 50, pct);
void ControllerInteraction::liftArm() {
// Arm Motor Forward
ArmMotors.spin(fwd, 50, pct);
void ControllerInteraction::lowerArm() {
// Arm Motor Reverse 50% power
ArmMotors.spin(reverse, 50, pct);
void ControllerInteraction::extendPiston() {
// Piston Motor Forward 50% power
PistonMotors.spin(fwd, 50, pct);
void ControllerInteraction::retractPiston() {
// Arm Motor Forward 50% power
PistonMotors.spin(reverse, 100, pct);
void ControllerInteraction::stopIntake() {
// Stopping Left Intake Motor
IntakeMotors.stop();
void ControllerInteraction::stopArm() {
// Stopping Arm Motor
ArmMotors.stop();
void ControllerInteraction::stopPiston() {
// Stopping Piston Motor
PistonMotors.stop();
void Driver::setDriverCieran() {
// Robot Movement Setup
// Tank Controls
Controller.ButtonLeft.pressed(nothing);
Controller.ButtonX.pressed(nothing);
Controller.ButtonA.pressed(nothing);
Controller.Screen.clearScreen();
Controller.Screen.print("Hello Cieran!");
// Set the left joystick Y Axis to move the left side of the robot
Controller.Axis3.changed(ControllerInteraction::moveLeftSide);
// Set the right joystick Y Axis to move the right side of the robot
Controller.Axis2.changed(ControllerInteraction::moveRightSide);
// Arm Movement Setup
// Controls for the arm
// Sets the left down button to lower the robot's arms
Controller.ButtonDown.pressed(ControllerInteraction::lowerArm);
Controller.ButtonDown.released(ControllerInteraction::stopArm);
// Sets the right down button(B) to raise the robot's arm
Controller.ButtonB.pressed(ControllerInteraction::liftArm);
Controller.ButtonB.released(ControllerInteraction::stopArm);
// Piston Control Setup
// Controls for the piston
// Sets the lowest front left button to lower the piston
Controller.ButtonL2.pressed(ControllerInteraction::retractPiston);
Controller.ButtonL2.released(ControllerInteraction::stopPiston);
// Sets the lowest front right button to raise the piston
Controller.ButtonR2.pressed(ControllerInteraction::extendPiston);
Controller.ButtonR2.released(ControllerInteraction::stopPiston);
// Intake Control Setup
// Controls for the intake system
// Sets the highest front left button to have the intake system pull
// objects towards the bot
Controller.ButtonL1.pressed(ControllerInteraction::pullIntake);
Controller.ButtonL1.released(ControllerInteraction::stopIntake);
// Sets the highest front right button to have the intake system push
// objects away from the bot
Controller.ButtonR1.pressed(ControllerInteraction::pushIntake);
Controller.ButtonR1.released(ControllerInteraction::stopIntake);
void Driver::setDriverCharlie() {
/* TODO:
- Get controls from charlie and update the callbacks with his desired
control scheme
void Driver::setDriverAndrew() {
Controller.Screen.print("Hello Andrew!");
// ~~~ Arm Movement Setup ~~~
// sets the down buttons pressed and released functions
Then in the userControl function within the main.cpp file I set the driver based on button input.
void usercontrol(void) {
Brain.Screen.render(true);
if (Controller.ButtonX.pressing()) {
Driver::setDriverAndrew();
} else if (Controller.ButtonLeft.pressing()) {
Driver::setDriverCieran();
} else if (Controller.ButtonA.pressing()) {
Driver::setDriverCharlie();
while (1) {
// prevent wasted resources.
Everything in this code works but the released functions. I am fairly sure that Button.pressed(callback) creates an event and does not need to be in a while loop but I could be incorrect. I am able to switch drivers but when I start a motor it does not stop on release. If anyone could help out it would be greatly appreciated.
