Removing a program from V5 Brain
Is it possible to remove programs from a V5 brain? For instance, say you download code into slot eight and you would like to remove it because you don’t want that code anymore, is there a way to remove it?
I’m not sure about removing one single code slot, but you can remove all of the programs in your brain by going to settings, and you’ll see a button where you can reset all programs.
You can use the V5 utility to view all the programs you have downloaded and delete which ever programs you would like.
V5 Utility was only provided to beta testers.
