Hello,
Vex Foam tiles are pretty expensive for what they are… Has anyone found tiles that are similar for a cheaper price point and can link me them?
Thanks
Hello,
Thanks
They are soft tiles brand tiles I believe. Other tiles generally have the middle key opposite from what you want or no key at all. The Vex bundle is pretty comparable in price but sometimes you just need one or two tiles to be replaced.
$6.40 each tile from soft tiles
$4.00 each if you don’t mind some dings…
Having a bag can help too.
If you don’t mind if they’re a little different and don’t need to fit with the VEX tiles, the cheapest ones that I have found are from Harbor Freight, and there are often coupons for them too.
However, these are not the exact same, and while I have found that they are more than good enough for practicing on, there are some small differences:
http://www.harborfreight.com/4-piece-anti-fatigue-foam-mat-set-94635.html
Thanks for the Softtiles link! What’s cool is that you can make custom name tiles and numbers. Imagine VEXmen at the center of your field! Not that anyone ever uses those white line tapes or tile colors to move around the field If you have $$$, they can even make a special tile with your logo on it…
Seriously, good place to get regulation replacement tiles without breaking the bank.
