Hi,
So basically, I’m trying to write some code that would record all of the motor movement during driver control in 10 msec intervals, write it to a text file, that we could copy and paste into a new autonomous mode. However, whenever I run it, none of it works. No input from the controller makes it move, and none of the movements are recorded. Here is the attached code:
#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition) \
do { \
wait(5, msec); \
} while (!(condition))
#define repeat(iterations) \
for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
motor bleft = motor(PORT1, ratio18_1, false);
motor bright = motor(PORT2, ratio18_1, true);
motor fleft = motor(PORT3, ratio18_1, true);
motor fright = motor(PORT4, ratio18_1, false);
motor lift1 = motor(PORT7, ratio18_1, true);
motor lift2 = motor(PORT8, ratio18_1, false);
motor lift3 = motor(PORT19, ratio18_1, true);
motor lift4 = motor(PORT20, ratio18_1, false);
motor clawMotor = motor(PORT11, ratio18_1, false);
controller Controller1 = controller(primary);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
#pragma endregion VEXcode Generated Robot Configuration
/* Module: main.cpp */
/* Author: {author} */
/* Created: {date} */
/* Description: V5 project */
// Include the V5 Library
#include "vex.h"
#include "iostream"
#include "fstream"
#include "string"
// Allows for easier use of the VEX Library
using namespace std;
#define STRING(num) #num
int main() {
while(true){
clawMotor.setStopping(hold);
Brain.Screen.clearScreen();
// place driver control in this while loop
// Capping speed
float sensitivity;
sensitivity = 1.0;
Controller1.Screen.clearLine(-1);
Controller1.Screen.print("75%");
// Mobile goal controls
if(Controller1.ButtonR1.pressing() == true){
lift1.spin(reverse);
lift2.spin(reverse);
else if(Controller1.ButtonR2.pressing() == true){
lift1.spin(fwd);
lift2.spin(fwd);
else {
lift1.stop();
lift2.stop();
if(Controller1.ButtonA.pressing() == true){
clawMotor.spin(fwd);
else if(Controller1.ButtonB.pressing() == true){
clawMotor.spin(reverse);
else {
clawMotor.stop();
/* IF KEITH WANTS SENSITIVITY BACK
if(Controller1.ButtonUp.pressing()){
sensitivity = 0.75;
else{}
if(Controller1.ButtonDown.pressing()){
sensitivity = 0.5;
Controller1.Screen.print("50%");
else{}
// Conveyor belt controls (when needed)
if(Controller1.ButtonL1.pressing()){
lift3.spin(fwd, 100, pct);
lift4.spin(fwd, 100, pct);
else if(Controller1.ButtonL2.pressing()){
lift3.spin(reverse, 100, pct);
lift4.spin(reverse, 100, pct);
else{
lift3.stop();
lift4.stop();
// Axis controls
lift1.setStopping(hold);
lift2.setStopping(hold);
lift3.setStopping(hold);
lift4.setStopping(hold);
fleft.setStopping(brake);
bleft.setStopping(brake);
fright.setStopping(brake);
bright.setStopping(brake);
fleft.spin(directionType::rev, Controller1.Axis3.position(percent)*sensitivity, velocityUnits::pct);
bleft.spin(directionType::rev, Controller1.Axis3.position(percent)*sensitivity, velocityUnits::pct);
fright.spin(directionType::fwd, Controller1.Axis2.position(percent)*sensitivity, velocityUnits::pct);
bright.spin(directionType::fwd, Controller1.Axis2.position(percent)*sensitivity, velocityUnits::pct);
float bleftspeed;
float brightspeed;
float fleftspeed;
float frightspeed;
float lift1speed;
float lift2speed;
float lift3speed;
float lift4speed;
float clawspeed;
string bleftdir;
string brightdir;
string fleftdir;
string frightdir;
string lift1dir;
string lift2dir;
string lift3dir;
string lift4dir;
string clawdir;
string bleftscript;
string brightscript;
string fleftscript;
string frightscript;
string lift1script;
string lift2script;
string lift3script;
string lift4script;
string clawscript;
string timing;
ofstream f;
bleftspeed = bleft.velocity(pct);
brightspeed = bright.velocity(pct);
fleftspeed = fleft.velocity(pct);
frightspeed = fright.velocity(pct);
lift1speed = lift1.velocity(pct);
lift2speed = lift2.velocity(pct);
lift3speed = lift3.velocity(pct);
lift4speed = lift4.velocity(pct);
clawspeed = clawMotor.velocity(pct);
// Please don't make me fix this...this is really tedious code.
if(bleft.rotation(deg) < 0){
bleftdir = "reverse";
else if (bleft.rotation(deg) > 0){
bleftdir = "fwd";
if(bright.rotation(deg) < 0){
brightdir = "reverse";
else if(bright.rotation(deg) > 0){
brightdir = "fwd";
if(fleft.rotation(deg) < 0){
fleftdir = "reverse";
else if(fleft.rotation(deg) > 0){
fleftdir = "fwd";
if(fright.rotation(deg) < 0){
frightdir = "reverse";
else if(fright.rotation(deg) > 0){
frightdir = "fwd";
if(lift1.rotation(deg) < 0){
lift1dir = "reverse";
else if(lift1.rotation(deg) > 0){
lift1dir = "fwd";
if(lift2.rotation(deg) < 0){
lift2dir = "reverse";
else if(lift2.rotation(deg) > 0){
lift2dir = "fwd";
if(lift3.rotation(deg) < 0){
lift3dir = "reverse";
lift3dir = "fwd";
if(lift4.rotation(deg) < 0){
lift4dir = "reverse";
else if(lift4.rotation(deg) > 0){
lift4dir = "fwd";
if(clawMotor.rotation(deg) < 0){
clawdir = "reverse";
else if(clawMotor.rotation(deg) > 0){
clawdir = "fwd";
string bleft_str(STRING(bleftspeed));
string bright_str(STRING(brightspeed));
string fleft_str(STRING(fleftspeed));
string fright_str(STRING(frightspeed));
string lift1_str(STRING(lift1speed));
string lift2_str(STRING(lift2speed));
string lift3_str(STRING(lift3speed));
string lift4_str(STRING(lift4speed));
string claw_str(STRING(clawspeed));
bleftscript = "bleft.spin(" + bleftdir + ", " + bleft_str + ");\n";
brightscript = "bright.spin(" + brightdir + ", " + bright_str + ");\n";
fleftscript = "fleft.spin(" + fleftdir + ", " + fleft_str + ");\n";
frightscript = "fright.spin(" + frightdir + ", " + fright_str + ");\n";
lift1script = "lift1.spin(" + lift1dir + ", " + lift1_str + ");\n";
lift2script = "lift2.spin(" + lift2dir + ", " + lift2_str + ");\n";
lift3script = "lift3.spin(" + lift3dir + ", " + lift3_str + ");\n";
lift4script = "lift4.spin(" + lift4dir + ", " + lift4_str + ");\n";
clawscript = "claw.spin(" + clawdir + ", " + claw_str + ");\n";
f.open("reruncode.txt");
f << "# Autonomous Code\n";
f << bleftscript;
f << brightscript;
f << fleftscript;
f << frightscript;
f << lift1script;
f << lift2script;
f << lift3script;
f << lift4script;
f << clawscript;
f << "wait(10, msec)";
f.close();
wait(10, msec);
return 0;
*Sorry about the awful formatting, “.v5cpp” files are not supported.
Is there a visible bug with my code or should I try a different approach? I would really appreciate some help!
Thanks!
edit: code tags added by moderators
