I am working on a program using the optical shaft encoders. i want to be able to reset the variable. i tried to use the assignment code block (EasyC V2) to make Encodername = 0. however it only resets it for a infantesimal amount of time and then goes back to where it would have been had i never have tried to reset it. is there a way to set it back to zero? this is what i tried:
while 1==1
OSE = StartEncoder(1)
while OSE >= 500
OSE = 0
however after setting to 0 it just goes back to the same number and keeps counting up.
In order to accomplish this, you need to preset the actual encoder (versus simply assigning a zero value to the same variable that you use to retireve your encoder value).
When you insert a “Optical Encoder” block into your code, select “Preset”. Once you define the port number, you will need to enter a value to preset the encoder to (“0” in this case). It should now look like this: PresetEncoder(1 , 0).
