Responding to "mebob" on thread "line follower HELP!!"
What is your Robot Doing??? If you leave the Robot connected to your PC with the Programming Cable, what does it display on the Terminal for Values???
How much contrast is there between the “line” and the surface that the line is on.
I have gotten some real good results with ALL the defaults using Black Electricians tape on mostly white linoleum. The Tracking is slow, and can get into an oscillation mode where it continuously over corrects.
