How do I reset the vexnet 802.11g cortex
Turn it off and on again?
BillGates55: Welcome to Microsft Support, how may I assist you today?
Spencer: Hello, I need to reset my cortex.
BillGates55: How are you doing this fine evening? May I call you Spencer?
Spencer: Just peachy. Sure.
BillGates55: That is great to here Spence. Let’s go through some troubleshooting techniques to help you solve your problem. Not to worry as I will exhaust all my resources until this problem is solved!!
BillGates55: First of all, have you tried turning your cortex off and then turning it back on?
Spencer: Yes
BillGates55: Wonderful!
BillGates55: Please allow me 2 minutes of your time to look for a solution to your problem.
**10 minutes later
BillGates55: Have you tried unplugging the cortex and then plugging in the cortex again?
Spencer: Yes
BillGates55: And it still doesn’t work?
Spencer: Correct
**20 minutes later
Spencer: No, let me try!!!
BillGates55: Please let me know when you have completed this task.
*1 millisecond later
Spencer: Done
BillGates55: Did that work?
Spencer: Not in the slightest
BillGates55: I am glad I could have been of assistance today, {customerID:23587209374882}. Would you be so kind as to fill out a survey to tell us how we did today? If so please visit this link https://goo.gl/forms/UH45pyuU3ePYn8aw1
**Chat Ended
(loosely based on actual events)
Why everyone hate Tech Support.
Do be sure that you unplug the backup 9V battery at some point in the sequence, otherwise it will do its job and keep things from fully shutting down.
In my experience it’s worse during competition.
i think there is a tiny hole in it to inset like a paper clip end and reset it.
Instead of resetting the vexnet (which am not certain is possible), maybe try updating the cortex and controllers’ firmware.
