The right joystick on my VEX V5 remote controller no longer works. I tried using the controller on different robots and different programs, but it has the same result. Every other button and the left joystick work as normal. Is there a way to fix this, or is this remote controller broken?
If the controller does not work across different robots and programs it is mostly likely the controller’s issue.
Have you tried reseting the controller? The issue could be that some electronics in the controller got knocked around. Just a guess though.
How do you reset the controller? Thank you.
official vex website for it
This worked! After resetting, the controller worked perfectly. Thank you so much!
No problem I am glad it worked
