Robot Battery Charging
How do I charge the Robot Brain’s battery?
The robot battery must be removed from the Brain to charge. Only use the VEX Robot Battery Charger.
Plug the power cord into an AC outlet. Insert the Robot Battery into the charger. The LED should turn red. The LED will turn green once the battery is charged. The battery will continue to trickle (slowly) charge after the LED is green.
