When I upload the new code it says it downloads but the program on the brain doesn’t change. This problem also applies to everything else in the program.
Make sure you are running the program in the correct slot, we’ve downloaded new code into the second program slot before and still been using the code in the first slot.
Well, there’s the standard:
Make sure your firmware is updated
Make sure you only have one window communicating with the brain
Check your USB cable
Check your USB port on your computer
Check with a different computer
It’s not the USB cable, I’m updated, and there’s only one window communicating with the brain.
It appears to be something to do with the vex program itself. Since I can upload to a new program slot but it keeps the prev set of code. The weird part is that it has saved the program but sends the wrong version over.
Another solution to this is to use a different editing program. VexCode is known to be a little buggy sometimes. Something like Pros or VScode might work a little better
@Johnny1, please T.H.I.N.K. before you post. I am not talking just about this particular post, but other ones as well that could be considered rude. It does not help anyone when you post things like:
I know that you said that you are just “stating your opinion just like everyone else,” but when you include things that could be taken as rude, it takes away from the post, and damages your reputation. I am not berating you or trying to make you look bad, but just trying to gently remind you to T.H.I.N.K. before you post.
VEX is a learning experience for everyone, and it is important to learn from our mistakes and make the necessary corrections.
