Robot Doesn't Stop Moving Forward During PID Loop
Hey guys, new(ish) programmer here. I’m trying to use a PID loop for my robot to move forward, but it isn’t stopping. The Proportional and Derivative values were easy to debug, but the Integral has been tough, as our robot doesn’t stop. I read through George Gillard’s guide to PID loops and I debugged a bit, but to no avail. The code is mostly based on MartinMaVEXForever’s YouTube series (huge props to him). Here’s the code, just a note that the integral value is just a placeholder, and I am using 2 quadrature encoders, one on each drive train. I am also using omniwheels.
#pragma config(Sensor, in1,    LeftPotentiometer, sensorPotentiometer)
#pragma config(Sensor, in2,    CenterLine,     sensorLineFollower)
#pragma config(Sensor, in3,    RightPotentiometer, sensorPotentiometer)
#pragma config(Sensor, in4,    GyroSensor,     sensorGyro)
#pragma config(Sensor, in6,    LeftLine,       sensorLineFollower)
#pragma config(Sensor, in7,    RightLine,      sensorLineFollower)
#pragma config(Sensor, dgtl3,  RightEncoder,   sensorQuadEncoder)
#pragma config(Sensor, dgtl7,  LeftEncoder,    sensorQuadEncoder)
#pragma config(Motor,  port2,           rightSideDrive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port3,           rightMobileGoal, tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           rightTipper,   tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port6,           leftSideDrive, tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port7,           leftTipper,    tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port9,           leftMobileGoal, tmotorVex393_MC29, openLoop)
#pragma DebuggerWindows("Globals")
#pragma DebuggerWindows("Motors")
void baseControl (int speed)
		motor[leftSideDrive] = speed;
		motor[rightSideDrive] = speed;
//reading: ticks -- 627.2ticks/revolution
// 1 turn of the wheels -- 4 inch wheels = 627.2 *2 ticks
//1 turn of each wheel 4*pi inches
//4*pi inches = 627.2*2 ticks
//ticks/inch = 627.2 * 2 /4*pi= 99.82198
int inchToTicks (float inch)
		int ticks;
		ticks = inch*99.82198;
		return ticks;
int fixTimerValue (float rawSeconds)
	int miliseconds;
	miliseconds = rawSeconds*1000;
	if (miliseconds < 250)
			miliseconds = 250;
	return miliseconds;
void PIDBaseControl (float target, float waitTime, float maxPower = 1)
		float Kp = 0.26;
		float Ki = 0.05;
		float Kd = 0.62;
		int RightSensor;
		int LeftSensor;
		RightSensor = SensorValue[RightEncoder]*-1;
		LeftSensor = SensorValue[LeftEncoder];
		int error;
		float proportion;
		int integralRaw;
		float integral;
		int lastError;
		int derivitave;
		float integralActiveZone = inchToTicks(3);
		int finalPower;
		bool timerBool = true;
		SensorValue(LeftEncoder) = 0;
		SensorValue(RightEncoder) = 0;
		clearTimer(T1);
		while(time1[T1] < fixTimerValue(waitTime))
			error = inchToTicks(target) - (2*LeftSensor);
			proportion = Kp*error;
			if (abs(error) < integralActiveZone && error != 0)
				integralRaw = integralRaw+error;
			else
				integralRaw = 0;
			integral = Ki*integralRaw;
			derivitave = Kd*(error-lastError);
		 	lastError = error;
		 	if (error == 0)
		 			derivitave = 0;
			finalPower = proportion+integral+derivitave; //proportion+derivitave + intergral
			if(finalPower > maxPower*127)
				finalPower = maxPower*127;
			else if(finalPower < -maxPower*127)
				finalPower= -maxPower*127;
			baseControl(finalPower);
			wait1Msec(40);
			if (error < 30)
					timerBool = false;
			if (timerBool)
				clearTimer(T1);
	baseControl(0);
task main()
	PIDBaseControl(1, 1, 0.5); //move forward 1 inches with 1 sec delay 50% power;
	motor[leftSideDrive] = 0;
	motor[rightSideDrive] = 0;
	wait1Msec(100);
Thanks in advance! If you have any questions just ask below. Any help is appreciated.
You’re using 2LeftSensor instead of 2SensorValue[LeftEncoder] to calculate your error. This means you’ve only read SensorValue[LeftEncoder] a single time and stored it as LeftSensor forever. Since target also doesn’t change, error will never change.
