I can see how it would be more consistent, but it looks like it slows it down by allot. Maybe if they sped up the rollers.
The rollers were by far the most difficult part of the robot because making 1 motor rollers that fit these specifications is something that has never been done before. You also have to understand that this complex robot was built in 3 days, which means there was absolutely no time for tuning. The rollers are agreeably, lack luster, but we still think rollers are extremely important for autonomous consistency and helping the driver. I donât know if you noticed in the rules, but this year they increased the object placement tolerance to ±1.5â instead of 1â, so rollers to help suck in the cube will be invaluable.
Oh I definitely agree, consistency is the most important aspect at this time period. I understand that it was built in 3 days and itâs definitely impressive for a ri3d, but Iâm just offering my critique. ![]()
Maybe this is crazy idea, but couldnât you power the intake rollers off the drive? Like when they drive goes forward they suck the cubes in?
You could, but (from personal experience) gearing things directly off the drive while the drive is being powered tends to be very detrimental.
Yeah thatâs probably true. I wouldnât do it personally but itâs an idea
We did think of this but it would have been logistically difficult and we would either never be able to spin the rollers backwards or the rollers would spit out cubes if we drove backwards.
Not if you ratcheted them offâŠ
Again, direct drive powering is probably not s good idea. Youâll want to be able to intake cubes stationary at times, and drive power makes that not doable. (Though if you do, make sure you gear the rollers up for speed for obvious reasons. 1:1 gearing wonât work well, I donât think.)
If you mean just put a ratchet in so it never can drive backwards that is what I meant by ânever be able to spin the rollers backwardsâ. I suppose you could attempt to make a double ratcheting system but that would take up a lot of space.
I did this on my summer Turning Point robot. It was terrible. I do not recommend this ever. Even though it is a different game, it is the same intaking principle.
Exactly why Iâm advising against it. But, if youâre going to make a bad decision, do it right!
Awesome robot! Especially for 3 days. It has many similarities to our robot we are in the building process of so it canât be too crazy. We are working on our âcube tubeâ and it is very similar to your robotâs with the opening and closing and the passive hooks. Ours should have a higher capacity like you were prototyping so Iâll post something in here if we get it working. Also would you say the lift on top of a four bar is necessary because Iâm predicting our robot will have trouble reaching the scoring zones. Great design!
Did the same as well with two double ratchets, one for each side of the drive, ruined one of our early designs lol
@Brian_9605A
Hi, this is mark and I have a couple of questions:
- is there enough support on the motors of your drive base?
- How efficient are the rollers of the robot?
- How would you improve this robot?
- Can you explain a little about the spacers and at the bottom of the claw?
- How does the little c - channel go straight down and be able to collect a cube
- Why are there rubber bands connecting the tiny c -channel?
- For the claw, is there gears connected to the two sides of the robot to make it move or
- Are the two axles of the claw directly connected to the motor?
- Did you use regular axles or did you use axles like 21S where they are make like a screw?
I will only be able to tell you the answers to one of these questions. (You might have too many to be honest) the reason Brian has a sprocket leading to 2 gears is because brian needed to reverse the direction of that side of the intake as it is driven by only one motor and chained across under where the cubes are contained
Ok here is my big question: In the reveal it showed that it can carry 3 cubes at a time and if the lift went straight down it would automatically collect the cube. How do you make it or build it if the there is tooo little space. do you use standoffs or spacers. It think some part of it is to roll into the other cube and lock it in. How do you make the passive hooks?
Hey Brian, I would appreciate it if you could send a couple of pictures of your dr4b and your claw it seems very interesting because this is the only dr4b mounted on something that would be moving out and the passive hooks seem to be doing a lot too. This would be very much appreciated.
Also a quick question: Do the rollers on your passive hooks move?
AND why did you not switch the bars from a c - channel to an l - channel?
