The robot was driving well and suddenly it started to malfunction . It is not following the program . It started shaking while we were driving , we decided to reprogram the robot and reset it.
The Vex Hardware is very resilient, so most likely it was caused by human error. You did the right steps on check-in your program and resetting the brain.
Can we get some pictures to diagnose the problem?
Tell us a story: Our robot looks like this … it has this drivetrain … this mechanism to … and this one to … and a final one to do… It is programmed to … with the drive train and … with mechanism one and … mechanism two. It started well and then at the point it was to … it did … As it was doing … it started to shake like the … and … and … were not working together.
We decided that our hair was on fire and to reprogram the robot and reset it.
Ailopez, try again, fill in the … as much as you can. Try to hit the 65,000 character limit in a post. In the next post put the code BEFORE your hair caught fire. You can’t tell us a story and then give us different code.
Thanks (and put your hair out)
