Robot Jitters
We are having problems with our robot jittering we have replaced everything that we think is an issue do y’all have any ideas? Here is a copy of my code :
where’s the code?
Do you mean its running slow or its not moving???
#pragma config(Sensor, in1, pot, sensorPotentiometer)
#pragma config(Sensor, in2, pot2, sensorPotentiometer)
#pragma config(Sensor, in3, pot3, sensorPotentiometer)
#pragma config(Sensor, in4, pot4, sensorPotentiometer)
#pragma config(Sensor, in8, pot8, sensorPotentiometer)
#pragma config(Sensor, dgtl1, Lim1, sensorTouch)
#pragma config(Sensor, dgtl8, Encoder1, sensorQuadEncoder)
#pragma config(Motor, port1, Extr_R, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, LF_Drive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port3, LB_Drive, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, L_Lift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port5, Claw, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, Chain_bar, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, R_Lift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, RF_Drive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port9, RB_Drive, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port10, Extr_L, tmotorVex393_HBridge, openLoop)
// This code is for the VEX cortex platform
#pragma platform(VEX2)
// Select Download method as “competition”
//Main competition background code…do not modify!
#include “Vex_Competition_Includes.c”
#define DB_THRESH 15 // Sets a deadband variable
void Claw1(int power, int timex, int constant_power){
motor(Claw) = power;
wait1Msec(timex);
motor(Claw) = constant_power;
void move(int power1, int power2, int timex) {
motor[LF_Drive] = power1;
motor[RF_Drive] = power1;
motor[LB_Drive] = power2;
motor[RB_Drive] = power2;
wait1Msec(timex);
motor[LF_Drive] = 0;
motor[RF_Drive] = 0;
motor[LB_Drive] = 0;
motor[RB_Drive] = 0;
void lift(int power, int timex, int constant_power){
motor[L_Lift] = power;
motor[R_Lift] = power;
wait1Msec(timex);
motor[L_Lift] = constant_power;
motor[R_Lift] = constant_power;
void extender(int power, int timex, int constant_power) {
motor[Extr_R] = power;
motor[Extr_L] = power;
wait1Msec(timex);
motor[Extr_L] = constant_power;
motor[Extr_R] = constant_power;
void chainbar(int power, int timex, int constant_power) {
motor[Chain_bar] = power;
wait1Msec(timex);
motor[Chain_bar] = constant_power;
void turn(int power1, int power2, int power3, int power4, int timex) {
motor[RF_Drive] = power2;
motor[LB_Drive] = power3;
motor[RB_Drive] = power4;
wait1Msec(timex);
void chainbar_lift(int power1, int power2, int timex, int constant_power1, int constant_power2, ){
motor[L_Lift] = power1;
motor[R_Lift] = power1;
motor[Chain_bar] = power2;
wait1Msec(timex);
motor[L_Lift] = constant_power1;
motor[R_Lift] = constant_power1;
motor[Chain_bar] = constant_power2;
void move_adv(int power1, int power2, int distance, int constant_power) {
// resetSensor(Encoder1);
SensorValue(Encoder1) =0;
while(abs(SensorValue(Encoder1)) < distance) {
motor[LF_Drive] = constant_power;
motor[RF_Drive] = constant_power;
motor[LB_Drive] = constant_power;
motor[RB_Drive] = constant_power;
void put_cone_on_high(int timex) {
// Initial WAIT in case we want to delay putting the cone on high… you have found the easter egg:) the easter bunny is happy for you
wait1Msec(timex);
// ###########   MAIN   AUTO PROGRAM ##############//
//go forward
//move_adv(60,-60,22,0);
Claw1(127,10,10);
move(67,-67, 525);
//lift up
lift(127,600,10);
//move chainbar to position
chainbar(-127,2000,0);
//open claw
Claw1(127,100,15);
wait1Msec(500);
lift(127,575,0);
//go backwords
move(-67,67, 485);
//lift chainbar
chainbar(127,1000,0);
//lower extender
lift(-127,1075,0);
void auton3(int timex) {
wait1Msec(timex);
chainbar(-100,1,-30); // CLAW holds cone
//lift tower
lift(100,900,0);
//extend goal grabber
extender(-127,1000,0);
//move(-127,127,2750);
move_adv(-55,55,1275,0); // Move forward
//lift extender
extender(127,1000,0);
// go backwards
move_adv(55,-55,1000,0);
//turn
turn(-60,60,60,-60,1695); // Turn Right
//go forwards
move_adv(-60,60,150,0);
extender(-127,1000,0); // Extend
move_adv(90,-90,275,0); // Move backward
void auton4(int timex) {
wait1Msec(timex);
//lift tower
lift(100,500,0);
//lift extender
// go backwards
//turn
turn(75,-75,-75,75,1695); // Turn left
//go forwards
void auton5(int timex) { // 60 sec auton
wait1Msec(timex);
//lift tower
lift(100,500,0);
//lift extender
// go backwards
//turn
//go forwards
//turn
//go forwards
//turn
//lower mogo
//go forwards
//raise mogo
//go backwards
//turn
//go forwards
//turn
//go forwards
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks
// running between Autonomous and Driver controlled modes. You will need to
// manage all user created tasks if set to false.
// Set bDisplayCompetitionStatusOnLcd to false if you don't want the LCD
// used by the competition include file, for example, you might want
// to display your team name on the LCD in this function.
// bDisplayCompetitionStatusOnLcd = false;
task autonomous()
// Insert user code here.
// Remove this function call once you have "real" code.
if(sensorvalue[Lim1]==1) {
	auton3(100); //Left Side -- going for 20
	//put_cone_on_high(100);
} else {
	auton4(100); // Right Side -- going for 10
task usercontrol()
//int pauser = 0;
while (true)
	//Driving Controls
	if(abs(vexRT(Ch3)) >= DB_THRESH || abs(vexRT(Ch2)) >= DB_THRESH ){ // Checks to see if the joystick is beyond the deadband
		// allows motors to run since beyond the deadband arcade
		motor[LF_Drive] = vexRT[Ch3] + vexRT[Ch4];
		motor[LB_Drive] = - vexRT[Ch3] + vexRT[Ch4];
		motor[RF_Drive] = vexRT[Ch3] + vexRT[Ch4];
		motor[RB_Drive] = - vexRT[Ch3] + vexRT[Ch4];
			//if(pauser < 1000){
				motor[LF_Drive] = - vexRT[Ch3];
				motor[LB_Drive] = + vexRT[Ch3];
				motor[RF_Drive] = - vexRT[Ch2];
				motor[RB_Drive] = + vexRT[Ch2];
			/*} else {
				wait10Msec(50);
				pauser=0;
		} else {
		// stop all drive motors within deadband, saves power and motors
	if(vexRT[Btn5U]){ // cone grabber up
		extender(100,10,100);
	else{
		extender(0,0,0);
	if(vexRT[Btn5D]){ // cone grabber down
		extender(-100,10,-100);
else{
	extender(0,0,0);
if(vexRT[Btn6U]){ // lift up - extend up
lift(127,20,10);
	if(vexRT[Btn6D]){ // lift down extend down
		lift(-127,20,-10);
	if(vexRT[Btn7D]){ // chainbar
		Claw1(127,10,127);
	else{
		Claw1(0,0,0);
	if(vexRT[Btn7U]){	// chainbar
		Claw1(-127,10,-127);
else{
	Claw1(0,0,0);
	if(vexRT[Btn8D]){ // claw
		chainbar(100,10,100);
else{
	chainbar(0,0,0);
	if(vexRT[Btn8U]){ // claw
		chainbar(-100,10,-100);
else{
	chainbar(0,0,-30);
	//if(vexRT[Btn8R]){
	//	chainbar_lift(100,-90,15,0,0);
if(vexRT[Btn8R]){
	turn(-60,60,60,60,20);
if(vexRT[Btn8L]){
	turn(60,-60,60,60,20);
	//pauser=pauser++;
/*bLCDBacklight = true; //turn on backlight
string mainBattery, backupBattery;
clearLCDLine(0);      //clear screen
clearLCDLine(1);      //clear screen
// battery voltage
displayLCDString(0, 0, "Primary: ");
sprintf(mainBattery, "%1.2f%c", nImmediateBatteryLevel/1000.0,'V');
displayNextLCDString(mainBattery);
displayLCDString(1, 0, "Secondary: ");
sprintf(backupBattery, “%1.2f%c”, BackupBatteryLevel/1000.0,‘V’);
displayNextLCDString(backupBattery);
//refresh rate
wait1Msec(100);*/
From my experience, that is probably motors overheating. You likely either have too high of gear ratio or too much friction.
I agree!!!
Is that what PROS looks like?
it stops and jitters (like shivering) then after awhile it works again
I heard of a team in our class that had an issue where they were accidentally telling the robot to stop and go at the same time because they used two difference else if statements when they should have used it all in one string.
You might need to check the ports or even replace the motors. That could Hurt your game in a competition.
like i said we have replaced everything (power expander, motors, cortex)
Have you checked the programming?
and we replaced the motor controller
Got to be something in code or you are gearing it with not enough torque.
It maybe that the gears are not lined up.
It might be cold
What do you mean by that?
This is a very common reason for jittering. We’ve had the same problem and it has always been the motors being told to do two different things at the same time.
