My team has started to cad our robot and we found the game manual size explanation confusing. Can someone clarify the starting size and expansion limit.
The game manual states pretty clearly, βRobots must fit within an 18β x 18β x 18β volume.β This is an 18 inch cube, so 18 inches in height, length, and width.
It also is very clear about expansion. βThe Robot can never be larger than 22β wide or 22β long.β and βNo part of the Robot may exceed an overall height of 22β at any point during the Match (must always be able to fit within a hypothetical 22βx22βx22β cubic sizing box).β
This is basically the same as beginning the match, just a bigger cube. The robot can never exceed 22 inches in length, width, or height during the match, but must start the match not exceeding 18 inches in length, width, or height.
Here is the game manual if you need it:
What did you find confusing?
The Robot can never be larger than 22β wide or 22β long (must always be able to fit within a 22βx22β square horizontal footprint).
This was taken straight from the 1.0 game manual. You may be looking at the 0.1 game manual, and the GDC has clarifyed since that the origanal wording was not their intent, and have changed it.
Basicly, your robot must start the match in a hypothetical cube that is 18 18 18", and can then expand to 22 22 22" once the match has started.
Examples of Minor Violations include, but are not limited to:
β Loose wires
β Broken zip ties / rubber bands
β Bent or broken mechanical components that are not used for strategic gain
This is part of rule , and it states the only reason the robot can expand past 22" legally is for accidental and non-stratigic incidents, so design your robot to prevent against this to prevent any violations.
Anyways, I hope this helped, and best of luck with your cad!
Are you in IQ or V5?
IQ
No additional horizontal expansion. Infinite vertical expansion
V5
Expant up to 22" x 22" x 22"
im new to V5, i just wanted to confirm before CADing a robot out of size, thank you for the responses!
Ooooh⦠yes i was looking at 0.1, thanks!
V5, this helped, thanks!
thank you for the explanation! this helped a lot!
hi TeamDynamite44600A you are able to use the quote function to combine your post into one post. you can do this by right clicking on something you want to reply to. please do this next time
