Ok my robot moves on it own without coding on it (I load a blank sleet when it happens)
1.I turn it on
2.I run my program (Before it glitched i have a post you have to read)
3.it says things arent connected
Then it starts to move on its own like turning and going forward
If you need context please comment I can't show the video because my computer does not upload videos
You may have an older program that is set to automatically run when the brain starts. You could try to ‘Reset all Settings’ on the brain. That would leave any programs that are there, but have the brain go back to original behavior.
I would recommend calibrating the controller because that might be the problem. If that doesn’t work you might have to buy a new controller. I had this problem a couple of years ago and the solution ended up being getting a new controller
