Hey forum, my robot isn’t able to connect to the field control system. The code compiles, but it won’t connect to the system. Here is the entirety of my code:
#include "robot-config.h"
/* Description: Competition template for VCS VEX V5 */
//Creates a competition object that allows access to Competition methods.
vex::competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the cortex has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton( void ) {
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void baseControl(int leftSpeed, int rightSpeed, int time)
//motor[leftFront] = leftSpeed;
LeftFront.spin( fwd, leftSpeed, velocityUnits::rpm );
//motor[leftBack] = leftSpeed;
LeftBack.spin( fwd, leftSpeed, velocityUnits::rpm );
//motor[rightFront] = rightSpeed;
RightFront.spin( fwd, rightSpeed, velocityUnits::rpm );
//motor[rightBack] = rightSpeed;
RightBack.spin( fwd, rightSpeed, velocityUnits::rpm );
//time = wait1Msec(time);
vex::task::sleep(time);
void sensorControl(double speed, int sensor)
LeftFront.setVelocity(speed,velocityUnits::rpm);
LeftBack.spin(directionType::fwd,speed, velocityUnits::rpm);
RightFront.spin(directionType::fwd,speed, velocityUnits::rpm);
RightBack.spin(directionType::fwd,speed, velocityUnits::rpm);
LeftFront.rotateFor(sensor,rotationUnits::deg);
LeftBack.setVelocity(0,velocityUnits::rpm);
RightBack.setVelocity(0,velocityUnits::rpm);
RightFront.setVelocity(0, velocityUnits::rpm);
LeftFront.setVelocity(0, velocityUnits::rpm);
void pivotControl(int speed, int pivot)
{ LeftFront.setRotation(0,rotationUnits::deg);
LeftBack.spin(directionType::fwd,-speed, velocityUnits::rpm);
LeftFront.rotateFor(pivot,rotationUnits::deg);
LeftFront.setVelocity(0,velocityUnits::rpm);
void flipControl(int flipSpeed, int time)
Roller.spin (fwd, flipSpeed, velocityUnits::rpm );
void armControl(float armSpeed, int time)
LeftArm.spin (fwd, armSpeed, velocityUnits::rpm );
RightArm.spin (fwd, armSpeed, velocityUnits::rpm );
void rawArmControl(float rawArmSpeed)
LeftArm.spin(fwd, rawArmSpeed, velocityUnits::rpm );
RightArm.spin(fwd, rawArmSpeed, velocityUnits::rpm );
void autonomous( void ) {
// Insert autonomous user code here.
flipControl(-100, 500);
flipControl(0, 100);
sensorControl(100, 1000);
baseControl(0, 100, 500);
baseControl(0, 0, 100);
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol( void ) {
float speed = 1;
while (1){
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
RightFront.spin(directionType::fwd,Controller1.Axis2.position(percentUnits::pct)/speed,velocityUnits::pct);
RightBack.spin(directionType::fwd,Controller1.Axis2.position(percentUnits::pct)/speed,velocityUnits::pct);
LeftFront.spin(directionType::fwd,Controller1.Axis3.position(percentUnits::pct)/speed,velocityUnits::pct);
LeftBack.spin(directionType::fwd,Controller1.Axis3.position(percentUnits::pct)/speed,velocityUnits::pct);
if(Controller1.ButtonR1.pressing()){
LeftArm.spin(directionType::fwd, 50, velocityUnits::pct);
RightArm.spin(directionType::fwd, 50, velocityUnits::pct);
else if (Controller1.ButtonR2.pressing()){
LeftArm.spin(directionType::rev, 50, velocityUnits::pct);
RightArm.spin(directionType::rev, 50, velocityUnits::pct);
else{
LeftArm.stop(brakeType::hold);
RightArm.stop(brakeType::hold);
if(Controller1.ButtonL1.pressing()){
Roller.spin(directionType::fwd, 50, velocityUnits::pct);
else if(Controller1.ButtonL2.pressing()){
Roller.spin(directionType::rev, 100, velocityUnits::pct);
else{
Roller.stop(brakeType::hold);
if(Controller1.ButtonUp.pressing()){
speed = 1.25;
else if(Controller1.ButtonDown.pressing()){
speed = 2;
if(Controller1.ButtonX.pressing()){
armControl(50, 2050);
if(Controller1.ButtonY.pressing()){
armControl(50, 1800);
if(Controller1.ButtonB.pressing()){
pivotControl(75, 285);
if(Controller1.ButtonA.pressing()){
sensorControl(-125, -1350);
vex::task::sleep(20); //Sleep the task for a short amount of time to prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
//Run the pre-autonomous function.
pre_auton();
//Set up callbacks for autonomous and driver control periods.
Competition.autonomous( autonomous );
Competition.drivercontrol( usercontrol );
//Prevent main from exiting with an infinite loop.
while(1) {
vex::task::sleep(100);//Sleep the task for a short amount of time to prevent wasted resources.
