I downloaded a program, which has worked many many times previously, to a Cortex, and the robot only drives in reverse. If the joysticks are pushed forward, there is no response at all from the robot. Any ideas?
#pragma config(Motor, port1, leftDrive, tmotorVex393_HBridge, openLoop, reversed)
#pragma config(Motor, port10, rightDrive, tmotorVex393_HBridge, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(1==1)
motor(port1) = vexRT(Ch2);//left drive left joystick
motor(port10) = vexRT(Ch3);//right drive right joysttick
