We have spent the last few days debugging our driver control program. We finally have what we want working then we disconnect from the computer and try to practice with it disconnected. We turn the cortex on and then all the motors are turned on, vexnet is not connected and the only way to get the robot back is to install the firmware again and redownload the program. Works fine connected to the computer, then try it again and it wigs out once again. I am at a loss of what to do to fix this. I’m 99% sure it is not the program. I attached the program anyways.
#pragma config(Sensor, I2C_1, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_2, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_3, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_4, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Motor, port1, leftMotor1, tmotorVex393HighSpeed_HBridge, openLoop, reversed, encoderPort, I2C_1)
#pragma config(Motor, port2, leftMotor2n3, tmotorVex393HighSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port3, lowIntake, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port4, highIntake, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, shooterMotor1, tmotorVex393_MC29, openLoop, encoderPort, I2C_4)
#pragma config(Motor, port6, shooterMotor2, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, shooterMotor3, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port8, distanceControlMotor, tmotorVex269_MC29, PIDControl, reversed, encoderPort, I2C_3)
#pragma config(Motor, port9, rightMotor2n3, tmotorVex393HighSpeed_MC29, openLoop)
#pragma config(Motor, port10, rightMotor1, tmotorVex393HighSpeed_HBridge, openLoop, encoderPort, I2C_2)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
motor port 1 - left drive motor 1 - with IME connected to I2C port on microcontroller
motor port 2 - left drive motor 2 split with left drive motor 3(middle gear wire reversed)
motor port 3 - low intake motor
motor port 4 - high intake motor
motor port 5 - to port A on power expander - shooter motor 1 - with IME connected to distanc eControlMotor IME
motor port 6 - to port B on power expander - shooter motor 2
motor port 7 - to port C on power expander - shooter motor 3
motor port 8 - to port D on power expander - distance control motor - with IME connected to rightMotor1 IME
motor port 9 - right drive motor 2 split with right drive motor 3(middle gear wire reversed)
motor port 10 - right drive motor 1 - with IME connected to leftMotor1 IME
int home = 1;
int zone1 = 0;
int zone2 = 0;
int zone3 = 0;
int count = 0;
task powerPresetDistance()
slaveMotor(port2, port1); //motors in port 2 will follow port 1
slaveMotor(port9, port10);//motors in port 9 will follow port 10
slaveMotor(port6, port5);//motors in port 6 will follow port 5
slaveMotor(port7, port5);//motors in port 7 will also follow port 5
resetMotorEncoder(distanceControlMotor);
while(1)
if(vexRT[Btn8LXmtr2] == 1) //home
home = 1;
zone1 = 0;
zone2 = 0;
zone3 = 0;
count = 0;
if(vexRT[Btn8UXmtr2] == 1)//zone 1
home = 0;
zone1 = 1;
zone2 = 0;
zone3 = 0;
count = 2000; //needs changed
if(vexRT[Btn8RXmtr2] == 1)//zone 2
home = 0;
zone1 = 0;
zone2 = 1;
zone3 = 0;
count = 1250; //needs changed
if(vexRT[Btn8DXmtr2] == 1)//zone 3
home = 0;
zone1 = 0;
zone2 = 0;
zone3 = 1;
count = 500; //needs changed
if(home == 1 && getMotorEncoder(distanceControlMotor) > count) //power to hgetMotorEncoder(distanceControlMotor) > countome position
home = 0;
while(getMotorEncoder(distanceControlMotor) > count)
motor[distanceControlMotor] = 63;
motor[distanceControlMotor] = 0;
if(zone1 == 1 && getMotorEncoder(distanceControlMotor) < count)//power to zone1 position
zone1 = 0;
while(getMotorEncoder(distanceControlMotor) < count)
motor[distanceControlMotor] = -63;
if(zone1 == 1 && getMotorEncoder(distanceControlMotor) > count)//power to zone1 position
zone1 = 0;
if(zone2 == 1 && getMotorEncoder(distanceControlMotor) < count)//power to zone2 position
zone2 = 0;
if(zone2 == 1 && getMotorEncoder(distanceControlMotor) > count)//power to zone2 position
zone2 = 0;
if(zone3 == 1 && getMotorEncoder(distanceControlMotor) < count)//power to zone2 position
zone3 = 0;
if(zone3 == 1 && getMotorEncoder(distanceControlMotor) > count)//power to zone2 position
zone3 = 0;
task main()
startTask(powerPresetDistance);
float speedController = 1;
while(1 == 1)
//drivetrain control -------------------------------
motor[leftMotor1] = vexRT[Ch3]*speedController;
motor[rightMotor1] = vexRT[Ch2]*speedController;
//intake control --------------------------------
if(vexRT[Btn5UXmtr2] == 1)
motor[lowIntake] = 127;
motor[highIntake] = 127;
else if(vexRT[Btn5DXmtr2] == 1)
motor[lowIntake] = -127;
motor[highIntake] = -127;
else
motor[lowIntake] = 0;
motor[highIntake] = 0;
//shooter control ------------------------------------
if(vexRT[Btn6UXmtr2] == 1)
motor[shooterMotor1] = 127;
else
motor[shooterMotor1] = 0;
//shooter power ------------------------------------
//if(vexRT[Btn7U] == 1)
// motor[distanceControlMotor] = 127;
//else if(vexRT[Btn7D] == 1)
// motor[distanceControlMotor] = -127;
//else
// motor[distanceControlMotor] = 0;
//controls drivetrain max power ----------------------------------
if(vexRT[Btn6U] == 1)
if(vexRT[Btn6D] == 1)
speedController = .5;
