I am programing my vex brain using Python. I am trying to use the inertial sensor for accurate turning but when I attach the turning to a for loop it will not make multiple turns. It makes the first turn and then skips over the turn. brain_inertial.set_rotation is suppose to be indented
def accurate_turn(degrees):
brain_inertial.set_rotation(0, DEGREES)
wait(.5, SECONDS)
driveMotors_motor_a.set_velocity(5, PERCENT)
driveMotors_motor_b.set_velocity(5, PERCENT)
wait(1, SECONDS)
if degrees > 0:
while brain_inertial.rotation(DEGREES) < degrees:
driveMotors_motor_a.spin(FORWARD)
driveMotors_motor_b.spin(REVERSE)
driveMotors.stop()
else:
while brain_inertial.rotation(DEGREES) > degrees:
driveMotors_motor_a.spin(REVERSE)
driveMotors_motor_b.spin(FORWARD)
driveMotors.stop()
#Main Program
brain_inertial.calibrate()
while brain_inertial.is_calibrating():
wait(50, MSEC)
for sides in range(4):
linear_movement(24)
wait(1, SECONDS)
accurate_turn(-90)
wait(1, SECONDS)
