Robot won't move when I start PID loop
When I start my code my robot won’t move. This is my first time ever doing PID and I followed a tutorial on YouTube.
This is the code I have made.
//Drive Settings
const int wheelTravel = 320;
const int trackWidth = 320;
const int wheelBase = 130;
motor_group driveL(leftMotorF, leftMotorM, leftMotorB);
motor_group driveR(rightMotorF, rightMotorM, rightMotorB);
drivetrain myDrivetrain(driveL, driveR, wheelTravel, trackWidth, wheelBase, mm);
//Settings
double kP = 0.0;
double kI = 0.0;
double kD = 0.0;
double turnkP = 0.0;
double turnkI = 0.0;
double turnkD = 0.0;
//Auton Settings
int desiredVaule = 500;
int desierdTurnValue = 0;
int error;
int prevError = 0;
int derivative;
int totalError = 0;
int turnError;
int turnPrevError = 0;
int turnDerivative;
int turnTotalError = 0;
bool resetDriveSensors = false;
bool enableDrivePID = true;
int drivePID(){
while(enableDrivePID){
if(resetDriveSensors){
  leftMotorF.setPosition(0, degrees);
  leftMotorM.setPosition(0, degrees);
  leftMotorB.setPosition(0, degrees);
  rightMotorF.setPosition(0, degrees);
  rightMotorM.setPosition(0, degrees);
  rightMotorB.setPosition(0, degrees);
//Get position of motors
int driveLPositionF = leftMotorF.position(degrees);
int driveLPositionM = leftMotorM.position(degrees);
int driveLPOsistionB = leftMotorB.position(degrees);
int driveRPosistionF = rightMotorF.position(degrees);
int driveRPosistionM = rightMotorM.position(degrees);
int driveRPositionB = rightMotorB.position(degrees);
////// Lateral Movement PID
//get average of the motors
int averagePosition = (driveLPositionF + driveLPositionM + driveLPOsistionB + driveRPosistionF + driveRPosistionM + driveRPositionB)/6;
//Postential
error = desiredVaule - averagePosition;
//Derivative
derivative = error - prevError;
//Integral
totalError += error;
double lateralMotorPower = (error * kP + derivative * kD + totalError * kI)/12;
///////Turning movement PID
//Get average of the two motors
int turnDifference = (driveLPositionF + driveLPositionM + driveLPOsistionB) - (driveRPosistionF + driveRPosistionM + driveRPositionB);
//Potential
turnError = turnDifference - desierdTurnValue;
//Derivative
turnDerivative = turnError - turnPrevError;
//Intergral
turnTotalError += turnError;
double turnMotorPower = (turnError * turnkP + turnDerivative * turnkD + turnTotalError * turnkI)/12;
driveL.spin(forward, lateralMotorPower + turnMotorPower, voltageUnits::volt);
driveR.spin(forward, lateralMotorPower - turnMotorPower, voltageUnits::volt);
prevError = error;
turnPrevError = turnError;
vex::task::sleep(20);
return 1;
void autonomous(void) {
vex::task pidMovment(drivePID);
desiredVaule = 500;
vex::task::sleep(1000);
All of your PID constants are set to 0. You need to at least set kP to a non-zero value in order for your robot to move.
