I just tested this and am able to confirm the different button mappings. The reason that this happens is because the uppercase Btn commands are the compiled mappings (Btn7U logically reads button 7 up) while the btn commands are the bit-masked values (in this case btn7U is referring to the horizontal axis of the right joystick, or axis 1). Because both are technically using the correct syntax in ROBOTC, it will not throw a compilation error at all.
Below is the ‘normal’ button mappings in ROBOTC:
Btn5D = 14,
Btn5U = Btn5D + 1,
Btn6D = Btn5D + 2,
Btn6U = Btn5D + 3,
Btn8D = Btn5D + 4,
Btn8L = Btn5D + 5,
Btn8U = Btn5D + 6,
Btn8R = Btn5D + 7,
Btn7D = Btn5D + 8,
Btn7L = Btn5D + 9,
Btn7U = Btn5D + 10,
Btn7R = Btn5D + 11,
And here are the bit-masked button groupings:
btn5D = 0x0001, // Button Group 5, Up
btn5U = 0x0002, // Button Group 5, Down
btn6D = 0x0004, // Button Group 6, Up
btn6U = 0x0008, // Button Group 6, Down
btn7D = 0x0100, // Button Group 7, Down
btn7L = 0x0200, // Button Group 7, Up
btn7U = 0x0400, // Button Group 7, Left
btn7R = 0x0800, // Button Group 7, Right
btn8D = 0x0010, // Button Group 8, Down
btn8L = 0x0020, // Button Group 8, Up
btn8U = 0x0040, // Button Group 8, Left
btn8R = 0x0080 // Button Group 8, Right
We plan on changing the names of the bit-masked button commands in the future (possibly to something like maskedbutton_Btn7U, for example), but in the meanwhile make sure you are using the correct capitalization when coding.
As always, thank you for the heads up on this and please do not hesitate to let us know if you run into any other issues, bugs, or glitches!
