using robotc for cortex would it be possible to press a button on the vex controller have a motor begin turning and stop once an encoder reached a certain value (using the optical shaft encoder)? how would it be done if so?
Yes, here’s an example.
#pragma config(Sensor, dgtl1, enc1, sensorQuadEncoder)
#pragma config(Motor, port1, motorA, tmotorVex393_HBridge, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
task main()
while(1) {
// Button press causes motor to move forward 1000 counts
if( vexRT Btn8U ] == 1 ) {
// clear encoder
SensorValue enc1 ] = 0;
// start motor
motor motorA ] = 100;
// wait for encoder value to be reached
// assumes encoder counts up as motor runs forward
while( SensorValue enc1 ] < 1000 ) {
wait1Msec(20);
// Stop Motor
motor motorA ] = 0;
// make sure button is released
while( vexRT Btn8U ] == 1 ) {
wait1Msec(10);
// no need to run any faster than this
wait1Msec(20);
