So I ran into a problem recently. I am trying to code a Logitech Gamepad F310, to work on Virtual Worlds for “In the Zone”. I inserted the code and it still doesn’t work. Does anyone have some kind of solution or a fix?https://images-na.ssl-images-amazon.com/images/I/91RsGVBf1IL._SL1500_.jpg
Does the Gamepad show in the device manager as a HID device?
Can you see values changing if you open the “Configure Joysticks” menu?
Have you tried using a sample program for “In the zone”, for example, “Fantasticbot - Arcade Control.c” ?
