I only ever use RobotC for Motor & Sensor Setup and compiling, so functions/macros to replace #pragmas and command-line compiling would be nice. I use Notepad++ the rest of the time.
However, yes, a dark theme, or even Notepad++'s custom themes, would be terrific. I might even switch back to the IDE for code writing.
Umm, yeah. So while you guys task the entire ROBOTC team with rewriting huge parts of GUI in ways that are not supported by Win32 (natively), I’d like to see… header files, function pointers, user configurable font and highlighting options, a proper and complete API guide.
It’s one file, download Sublime Text/Notepad++ and write your code there and copy it in RC periodically if you absolutely must have a dark theme. That’s what I did, because yes. I CAN’T STAND THE WHITE UI (but I’d still worry about other things first).
But like seriously.
A UI Design Overhaul would be great
I get that something like that would be ridiculous to ask and wont happen anytime soon, but RobotC needs a redesign
The dark theme would actually be incredibly easy to implement in ROBOTC 4.xx. Really though what isn’t complete about the current api.
When you say you want function pointers what you really mean is a complete overhaul of the compiler which is a ton of work.
Also header files without a real linker would just be the equivalent of more c files included before the real c files. So really what your asking for is another overhaul of the compiler to add a traditional linker.
