ROBOTC Graphical Natural Language - Sneak Peek
Just in time for the holidays, we are happy to give a sneak peek into the new and upcoming “Graphical Natural Language”!
Today we’re proud to give you a sneak peek to a new feature we’re calling “Graphical Natural Language”. This new interface will allow you to program robots from inside ROBOTC with easy-to-use graphical blocks that can be drag-and-dropped to form a program. Each block represents an individual command from the “text-based” ROBOTC and Natural Language.
Each block is custom designed to fit the needs for that specific function and parameters. Using text boxes and drop-down menus, users can customize each values of each function to solve various challenge and activities using the same commands as ROBOTC’s Text-Based Natural Language.
We have also added some new language extensions to both ROBOTC and Natural Language, such as the simplistic “Repeat” command. Prior to the Repeat command, users would need to copy and paste large sections of code or use a looping structure (like a ‘for’ or ‘while loop) in order to have a set of actions repeat a certain number of times. With the new “Repeat” command, however, users can simply specify how many times they would like for the code to run, with no complex coding required.
For more information on the exciting new features coming to ROBOTC for VEX Robotics 4.0, check out our blog post at the link below!
www.robotc.net is down
Most of it is back up now.
