Someone help me with this, I found this off of the internet, but my robot is only going in circles (this is RobotC):
#pragma config(UART_Usage, UART1, uartVEXLCD, baudRate19200, IOPins, None, None)
#pragma config(UART_Usage, UART2, uartNotUsed, baudRate4800, IOPins, None, None)
#pragma config(Motor, port3, frontLeft, tmotorVex269, openLoop)
#pragma config(Motor, port2, rearLeft, tmotorVex269, openLoop)
#pragma config(Motor, port5, rearRight, tmotorVex269, openLoop)
#pragma config(Motor, port4, frontRight, tmotorVex269, openLoop)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
* Radian to Holonomic Output Testing Code
* Licensend under the Lesser General Public License v3.0. http://goo.gl/fB9rz (c) 2013
* Author: Elliot Berman
// In order for the trigonometry functions to work correctly, all drivetrain motors
// should have a +PWM value corresponding to a clockwise rotation on the wheel.
#include "HolonomicRadians.h";
typedef enum {
left = 1,
center = 2,
right = 4
} cLCDButtons;
task main()
// Option 1: Full Joystick Control
displayLCDCenteredString(0,"Testing Holonomic");
displayLCDCenteredString(1,"loading...");
wait1Msec(500);
bLCDBacklight = true;
if(nVexRCReceiveState & vrXmit1)
// Jumper clip is plugged into digital port 1, and there is currenty a joystick connected
PolarJoystick joystick;
displayLCDCenteredString(0,"Using Joystick");
while(true)
clearLCDLine(1);
getPolarJoy(&joystick.radians, &joystick.speed);
HolonomicRadianOutput(joystick.radians, joystick.speed, vexRT[Ch4]);
writeDebugStreamLine("r: %f , s: %f",joystick.radians, joystick.speed);
wait1Msec(10);
//End of Option 1
else // Jumper clip not plugged in and/or joystick is not connected
//Option 2: Use LCD Screen or Ch8 joystick buttons to cycle through all multiples of PI/4 for [0,2PI)
bool leftLCDPressed = false;
bool rightLCDPressed = false;
bool leftJoyPressed = false;
bool rightJoyPressed = false;
bool centerLCDPressed = false;
bool downJoyPressed = false;
bool killSwitch = false;
int radianMultiplier = 0;
while(true)
// Check the left LCD Button for changes
if(nLCDButtons == left && !leftLCDPressed)
radianMultiplier--;
leftLCDPressed = true;
else if(nLCDButtons != left) leftLCDPressed = false;
// Check the right LCD button for changes
if(nLCDButtons == right && !rightLCDPressed)
radianMultiplier++;
rightLCDPressed = true;
else if(nLCDButtons != right) rightLCDPressed = false;
// Check the left Ch 8 button for changes
if(vexRT[Btn8L] && !leftJoyPressed)
radianMultiplier--;
leftJoyPressed = true;
else if(!vexRT[Btn8L]) leftJoyPressed = false;
// Check the right Ch 8 button for changes
if((vexRT[Btn8R]) && !rightJoyPressed)
radianMultiplier++;
rightJoyPressed = true;
else if(!vexRT[Btn8R]) rightJoyPressed = false;
// Check the center LCD button for changes
if(nLCDButtons == center && centerLCDPressed == false) {
killSwitch = killSwitch ? false : true;
centerLCDPressed = true;
else if(nLCDButtons != center) centerLCDPressed = false;
// Check the right Ch8 Button for changes
if(vexRT[Btn8D] && !downJoyPressed)
downJoyPressed = true;
else if(!vexRT[Btn8D]) downJoyPressed = false;
// We want the values to cycle, so when we go beyond bounds, go to the start of the opposite bound
if(radianMultiplier > 7) radianMultiplier = 0;
if(radianMultiplier < 0) radianMultiplier = 7;
displayLCDCenteredString(0,"Cycling RadPI/4");
switch(radianMultiplier)
case 0: displayLCDCenteredString(1,"Direction: 0"); break;
case 1: displayLCDCenteredString(1,"Direction: PI/4"); break;
case 2: displayLCDCenteredString(1,"Direction: PI/2"); break;
case 3: displayLCDCenteredString(1,"Direction: 3PI/4"); break;
case 4: displayLCDCenteredString(1,"Direction: PI"); break;
case 5: displayLCDCenteredString(1,"Direction: 5PI/4"); break;
case 6: displayLCDCenteredString(1,"Direction: 3PI/2"); break;
case 7: displayLCDCenteredString(1,"Direction: 7PI/4"); break;
default: displayLCDCenteredString(1,"ERROR");
if(!killSwitch) HolonomicRadianOutput(((float)radianMultiplier*(PI/4)),1,0); // the last 1,0 is optional, as it is defaulted to those vals
else if(killSwitch)
motor[frontLeft] = 0;
motor[frontRight] = 0;
motor[rearRight] = 0;
motor[rearLeft] = 0;
// End of Option 1
// Debugging Option 3: Runs the "traditional" holonomic code (no trig function). Should be used for determining hardware vs software issues
while(true) {
motor[rearRight] = vexRT[Ch2] - vexRT[Ch4] - vexRT[Ch1];
motor[frontRight] = vexRT[Ch2] - vexRT[Ch4] + vexRT[ch1];
motor[frontLeft] = -vexRT[Ch2] + vexRT[Ch4] - vexRT[Ch1];
motor[rearLeft] = -vexRT[Ch2] + vexRT[Ch4] + vexRT[Ch1];
.h file:
* HolonomicRadians.h
#define maxMotorSpeed 127
#define numberOfMotors 4
//**-----------------------SUPPORT FUNCTIONS-----------------------------------**//
float FindMaxFloat(float a, float b, float c = (0), float d = (0), float e = (0),
float f = (0), float g = (0), float h = (0), float i = (0), float j = (0))
float values] = {a,b,c,d,e,f,g,h,i,j};
float maxValue = 0;
for(int z = 0; z < 9; z++) {
if(abs(values[z]) > maxValue) maxValue = abs(values[z]);
return maxValue;
//**-----------------------MAIN FUNCTIONS------------------------------------**//
void HolonomicRadianOutput(float radians, float speed = 1, byte rotation = 0)
// Please refer to README.txt for a full explanation of the formulas used.
if(speed > 0)
float frontLeftOutput = -maxMotorSpeed * cos(PI/4 - radians),
frontRightOutput = maxMotorSpeed * cos(PI/4 + radians),
rearRightOutput = maxMotorSpeed * cos(PI/4 - radians),
rearLeftOutput = -maxMotorSpeed * cos(PI/4 + radians);
frontLeftOutput += rotation;
frontRightOutput += rotation;
rearRightOutput += rotation;
rearLeftOutput += rotation;
float maxOutput = FindMaxFloat(frontLeftOutput, frontRightOutput, rearRightOutput, rearLeftOutput);
// The goal is to rescale all values to -127<=out<=127. See README.txt for algebraic explanation.
speed *= (maxMotorSpeed / maxOutput);
frontLeftOutput *= speed;
frontRightOutput *= speed;
rearLeftOutput *= speed;
rearRightOutput *= speed;
motor[frontLeft] = (byte)frontLeftOutput;
motor[frontRight] = (byte)frontRightOutput;
motor[rearLeft] = (byte)rearLeftOutput;
motor[rearRight] = (byte)rearRightOutput;
else if (rotation > 20 || rotation < -20)
motor[frontLeft] = rotation;
motor[frontRight] = rotation;
motor[rearLeft] = rotation;
motor[rearRight] = rotation;
else
#define JOY_Y_DEADBAND 20
#define JOY_X_DEADBAND 20
typedef struct
float radians;
float speed;
} PolarJoystick;
void getPolarJoy(float *radians, float *speed, TVexJoysticks joy_x = Ch2, TVexJoysticks joy_y = Ch1) {
byte x_val = vexRT[joy_x];
byte y_val = vexRT[joy_y];
if((abs(x_val) < 20) && (abs(y_val) < 20)) {
*radians = 0;
*speed = 0;
else {
*radians = atan2(y_val,x_val);
float tmpSpeed = sqrt((y_val * y_val) + (x_val * x_val));
*speed = tmpSpeed/127;
if(*speed > 1) *speed = 1;
