It still has the error. Here is all of the code
#pragma config(Sensor, in1, LeftPot, sensorPotentiometer)
#pragma config(Sensor, in2, RightPot, sensorPotentiometer)
#pragma config(Sensor, dgtl7, RightButton, sensorTouch)
#pragma config(Sensor, dgtl8, LeftButton, sensorTouch)
#pragma config(Sensor, dgtl10, OARight, sensorTouch)
#pragma config(Sensor, dgtl11, DALeft, sensorTouch)
#pragma config(Sensor, dgtl12, DARight, sensorTouch)
#pragma config(Sensor, I2C_1, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_2, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_3, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Sensor, I2C_4, , sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Motor, port1, RightFront, tmotorVex393, openLoop)
#pragma config(Motor, port2, RightBack, tmotorVex393, openLoop, reversed, encoder, encoderPort, I2C_1, 1000)
#pragma config(Motor, port3, IntakeLeft, tmotorVex393, openLoop)
#pragma config(Motor, port4, IntakeRight, tmotorVex393, openLoop)
#pragma config(Motor, port5, SWLeft, tmotorVex393, openLoop, encoder, encoderPort, I2C_3, 1000)
#pragma config(Motor, port6, SWRight, tmotorVex393, openLoop, encoder, encoderPort, I2C_2, 1000)
#pragma config(Motor, port7, LiftRight, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port8, LiftLeft, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port9, LeftFront, tmotorVex393, openLoop, reversed)
#pragma config(Motor, port10, LeftBack, tmotorVex393, openLoop, encoder, encoderPort, I2C_4, 1000)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
#pragma platform(VEX)
//Competition Control and Duration Settings
#pragma autonomousDuration(15) //Autonomous is 15 seconds long
#pragma userControlDuration(105) //Driver control is 105 (1min 45sec) seconds long
#include "Vex_Competition_Includes.c" //Main competition background code...do not modify!
#include "Functions.c"
// Pre-Autonomous Functions
// You may want to perform some actions before the competition starts. Do them in the
// following function.
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks running between
// Autonomous and Tele-Op modes. You will need to manage all user created tasks if set to false.
nMotorEncoder[RightBack] = 0;
nMotorEncoder[LeftBack] = 0;
// Autonomous Task
// This task is used to control your robot during the autonomous phase of a VEX Competition.
// You must modify the code to add your own robot specific commands here.
task autonomous()
while(SensorValue(LeftButton) == 0) && (SensorValue(RightButton) == 0);
//be lazy
if(SensorValue(LeftButton) == 1) //Pick up bonus sack under trough with object and score in trough
motor[RightFront] = -127;
motor[RightBack] = -127;
motor[LeftFront] = -127;
motor[LeftBack] = -127;
wait1Msec(100);
motor[RightFront] = 0;
motor[RightBack] = 0;
motor[LeftFront] = 0;
motor[LeftBack] = 0;
wait1Msec(1000);
motor[IntakeLeft] = 127;
motor[IntakeRight] = 127;
motor[RightFront] = 127; //Drives forward full power
motor[RightBack] = 127;
motor[LeftFront] = 127;
motor[LeftBack] = 127;
wait1Msec(2500); //Drives forward at full power for 2 sec.
wait1Msec(1000);
motor[LiftLeft] = 127;
motor[LiftRight] = 127;
wait1Msec(1750);
motor[LiftLeft] = 0;
motor[LiftRight] = 0;
wait1Msec(425);
motor[IntakeLeft] = -127;
motor[IntakeRight] = -127;
wait1Msec(1000);
motor[IntakeLeft] = 0;
motor[IntakeRight] = 0;
wait1Msec(750);
wait1Msec(1200);
motor[LiftLeft] = -127;
motor[LiftRight] = -127;
wait1Msec(100);
else
if(SensorValue(RightButton) == 1) //Score bonus sack in high goal
wait1Msec(2200);
motor[RightFront] = -63;
motor[RightBack] = -63;
motor[LeftFront] = -63;
motor[LeftBack] = -63;
wait1Msec(500);
wait1Msec(500);
motor[SWLeft] = 127;
motor[SWRight] = 127;
wait1Msec(400);
motor[SWLeft] = 0;
motor[SWRight] = 0;
motor[RightFront] = -100;
motor[RightBack] = -100;
motor[LeftFront] = -100;
motor[LeftBack] = -100;
wait1Msec(100);
wait1Msec(2050);
wait1Msec(250);
motor[RightFront] = 100;
motor[RightBack] = 100;
motor[LeftFront] = 100;
motor[LeftBack] = 100;
wait1Msec(1500);
wait1Msec(500);
wait1Msec(1000);
// User Control Task
// This task is used to control your robot during the user control phase of a VEX Competition.
task usercontrol()
while (true)
motor[LeftFront] = vexRT[Ch3]; //Left joystick drives left side
motor[LeftBack] = vexRT[Ch3]; //Left joystick drives left side
motor[RightFront] = vexRT[Ch2]; //Right joystick drives left side
motor[RightBack] = vexRT[Ch2]; //Right joystick drives left side
motor[SWLeft] = (vexRT[Btn6U] - vexRT[Btn5U])*127; //Left/Right top/back buttons strafe left/right
motor[SWRight] = (vexRT[Btn6U] - vexRT[Btn5U])*127; //Left/Right top/back buttons strafe left/right
motor[LiftLeft] = (vexRT[Btn7UXmtr2] - vexRT[Btn7DXmtr2])*127;
motor[LiftRight] = (vexRT[Btn7UXmtr2] - vexRT[Btn7DXmtr2])*127;
motor[IntakeLeft] = (vexRT[Btn8DXmtr2] - vexRT[Btn8UXmtr2])*127;
motor[IntakeRight] = (vexRT[Btn8DXmtr2] - vexRT[Btn8UXmtr2])*127;
About the function error. Alright, never mind. I just forgot to space out the ( ). Everything’s fine with that.
