We are getting some strange errors when attempting to use a code we wrote. Here is the code. Any help would be awesome!
This is the errors we get:
Warning:Mismatched typedefs. Converting typedef ‘char’ to typedef ‘TVexReceiverState’, value ‘vrXmit1’
Error:Undefined variable ‘Program’. ‘short’ assumed.
#pragma config(Motor, port1, motor, tmotorVex269_HBridge, openLoop)
/ Description: Competition template for VEX EDR /
// This code is for the VEX cortex platform
#pragma platform(VEX2)
// Select Download method as “competition”
//Main competition background code…do not modify!
#include “Vex_Competition_Includes.c”
/* Pre-Autonomous Functions /
/ You may want to perform some actions before the competition starts. /
/ Do them in the following function. You must return from this function /
/ or the autonomous and usercontrol tasks will not be started. This /
/ function is only called once after the cortex has been powered on and /
/ not every time that the robot is disabled. /
void pre_auton()
// Set bStopTasksBetweenModes to false if you want to keep user created tasks
// running between Autonomous and Driver controlled modes. You will need to
// manage all user created tasks if set to false.
int lcdScreenMin = 1;
int lcdScreen = 1;
int lcdScreenMax = 3;
bLCDBacklight = true;
const short leftButton = 1;
const short centerButton = 2;
const short rightButton = 4;
while(vrDisabled == 1)
if(nLCDButtons == leftButton)
if(lcdScreenMin == lcdScreen)
lcdScreen = lcdScreenMax;
wait1Msec(250);
else
lcdScreen--;
wait1Msec(250);
if(nLCDButtons == rightButton)
if(lcdScreenMax == lcdScreen)
lcdScreen = lcdScreenMin;
wait1Msec(250);
else
lcdScreen++;
wait1Msec(250);
else if(nLCDButtons == leftButton)
wait1Msec(250);
else
lcdScreen--;
wait1Msec(250);
if(lcdScreen == 1 && Program != 1)
displayLCDCenteredString(0, "program");
displayLCDCenteredString(1, "1");
if(nLCDButtons == centerButton)
Program = lcdScreen;
displayLCDCenteredString(0, "autonomous has");
displayLCDCenteredString(1, "been selected");
wait1Msec(1500);
else if(lcdScreen == 1 && Program == 1)
displayLCDCenteredString(1, "[1]");
else if(lcdScreen == 2 && Program !=2)
displayLCDCenteredString(1, "2");
wait1Msec(1500);
else if(lcdScreen == 2 && Program == 2)
displayLCDCenteredString(1, "[2]");
else if(lcdScreen == 3 && Program !=3)
displayLCDCenteredString(1, "3");
wait1Msec(1500);
else if(lcdScreen == 3 && Program == 3)
displayLCDCenteredString(1, "[3]");
// Set bDisplayCompetitionStatusOnLcd to false if you don't want the LCD
// used by the competition include file, for example, you might want
// to display your team name on the LCD in this function.
// bDisplayCompetitionStatusOnLcd = false;
/ Autonomous Task /
/ This task is used to control your robot during the autonomous phase of /
/ a VEX Competition. /
/ You must modify the code to add your own robot specific commands here. /
task autonomous()
if(Program == 1)
motor[port1] = 50;
wait(2);
motor[port1] = 0;
else if(Program == 2)
motor[port1] = 60;
wait(4);
motor[port1] = 0;
else if(Program == 3)
motor[port1] = 70;
wait(6);
motor[port1] = 0;
// Remove this function call once you have "real" code.
AutonomousCodePlaceholderForTesting();
/ User Control Task /
/ This task is used to control your robot during the user control phase of /
task usercontrol()
while (true)
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
UserControlCodePlaceholderForTesting();
orangeload.docx (13.1 KB)
