Robotc PID loop help
This is my first time coding a PID loop and im not sure if this code will work for autonomous. I still have to mess with the Kp, Ki, and Kd values.
#pragma config(Sensor, dgtl1,  ,               sensorQuadEncoder)
#pragma config(Sensor, dgtl3,  ,               sensorQuadEncoder)
/*        Description: Competition template for VEX EDR                      */
// This code is for the VEX cortex platform
#pragma platform(VEX2)
// Select Download method as "competition"
//Main competition background code...do not modify!
#include "Vex_Competition_Includes.c"
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the cortex has been powered on and    */
/*  not every time that the robot is disabled.                               */
float Kp = 0;
float Ki = 0;
float Kd = 0;
void moveForward(float distance)
float errorLeft;
float errorRight;
float errorTotalLeft;
float errorTotalRight;
float lastErrorLeft;
float lastErrorRight;
float proportionLeft;
float proportionRight;
float integralLeft;
float integralRight;
float integralActiveZone = 57;
float derivativeLeft;
float derivativeRight;
float speedLeft;
float speedRight;
//convert distance in inches to raw values
errorLeft = distance * 57.2967795;
errorRight = distance * 57.2967795;
//calculates new error based on distance left from objective
errorLeft = errorLeft - SensorValue(dgtl1);
errorRight = errorRight - SensorValue(dgtl3);
if(errorLeft < integralActiveZone && errorLeft != 0)
	errorTotalLeft += errorLeft;
else
	errorTotalLeft = 0;
if(errorRight < integralActiveZone && errorRight != 0)
	errorTotalRight += errorRight;
else
errorTotalRight = 0;
//proportion values
proportionLeft = errorLeft * Kp;
proportionRight = errorRight * Kp;
//integral values
integralLeft = errorTotalLeft * Ki;
integralRight = errorTotalRight * Ki;
//derivative values
derivativeLeft = (errorLeft - lastErrorLeft) * Kd;
derivativeRight = (errorRight - lastErrorRight) * Kd;
//add P, I, and D to get motor speed
speedLeft = (proportionLeft + integralLeft + derivativeLeft);
speedRight = (proportionRight + integralRight + derivativeRight);
//motors move at speed found
motor(port1) = speedLeft;
motor(port3) = speedRight;
//make error into lastError after loop
lastErrorLeft = errorLeft;
lastErrorRight = errorRight;
wait1Msec(25); //let motors and cortex catch up
void moveBackward(float distance)
float errorLeft;
float errorRight;
float integralLeft;
float integralActiveZone = -57;
float speedLeft;
float speedRight;
errorLeft = distance * -57.2967795;
errorRight = distance * -57.2967795;
if(errorLeft > integralActiveZone && errorLeft != 0)
else
	errorTotalLeft = 0;
if(errorRight > integralActiveZone && errorRight != 0)
else
//proportion values
//integral values
//derivative values
void turnRight(float degrees)
float errorLeft;
float errorRight;
float integralLeft;
float speedLeft;
float speedRight;
//right side back, left side front
//627.2 ticks per revolution
//how many ticks is in 1 degree
errorLeft = (degrees/360) * 79.9718928869;
errorRight = (degrees/360) * -79.9718928869;
else
	errorTotalLeft = 0;
else
//proportion values
//integral values
//derivative values
void turnLeft(float degrees)
float errorLeft;
float errorRight;
float integralLeft;
float speedLeft;
float speedRight;
//left side back, right side front
errorLeft = (degrees/360) * -79.9718928869;
errorRight = (degrees/360) * 79.9718928869;
else
	errorTotalLeft = 0;
else
//proportion values
//integral values
//derivative values
void pre_auton()
  // Set bStopTasksBetweenModes to false if you want to keep user created tasks
  // running between Autonomous and Driver controlled modes. You will need to
  // manage all user created tasks if set to false.
SensorValue(dgtl1) = 0;
SensorValue(dgtl3) = 0;
	// Set bDisplayCompetitionStatusOnLcd to false if you don't want the LCD
	// used by the competition include file, for example, you might want
	// to display your team name on the LCD in this function.
	// bDisplayCompetitionStatusOnLcd = false;
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
task autonomous()
moveForward(20);
moveBackward(13);
turnRight(90);
moveForward(20);
moveBackward(20);
turnLeft(90);
void moveforward (int speed)
	slaveMotor(motorleft, motorleftbottom);
	slaveMotor(motorright, motorrightbottom);
	slaveMotor(motorlaunch, motorlaunch2);
	motor[motorleftbottom] = speed;
	motor[motorrightbottom] = speed;
void moveleft (int speed)
	motor[motorleftbottom] = -speed;
int inchToTicks (float inch)
	int ticks;
	ticks = inch*99.82198;
	return ticks;
int degreestoticks (float degree)
	float radius = 6.5;
	float circumference = 2*PI*radius;
	int ticksperturn = inchToTicks(circumference);
	int ticks = ticksperturn*degree/360;
	return ticks;
void PIDturn (float degree, float maxpower = 1)
	bool timerBool = true;
	clearTimer(T1);
	float kp = .2;
	float ki = 0;
	float kd = 0;
	int error;
	int proportion;
	int finalpower;
	int lasterror;
	int derivative;
	int integralRaw;
	float integralactivezone;
	float integral;
	SensorValue[motorright] = 0;
	SensorValue[motorleft] = 0;
	while(timerBool != false)
		error = degreestoticks(degree) - (SensorValue[motorrightbottoms]/2);
		proportion = error * kp;
		lasterror = error;
		derivative = kd*(error - lasterror);
		if (error == 0)
			derivative = 0;
		integralactivezone = inchToTicks(3);
		if(abs(error) <= integralactivezone && error != 0)
			integralRaw = integralRaw + error;
		else
			integralRaw = 0;
		integral = integralRaw * ki;
		finalpower = proportion + integral + derivative;
		if(finalpower > maxpower*127)
			finalpower = maxpower*127;
		else if(finalpower < -maxpower*127)
			finalpower = -maxpower*127;
		moveleft(finalpower);
		wait1Msec(40);
		if(error <= inchToTicks(0.5))
			timerBool = false;
	moveleft(0);
	wait1Msec(100);
	clearTimer(T1);
void PIDforward (int target, float maxpower = 1)
	float kp = .2;
	float ki = 0;
	float kd = 0;
	int error;
	int proportion;
	int finalpower;
	int lasterror;
	int derivative;
	int integralRaw;
	float integral;
	clearTimer(T1);
		error = inchToTicks(target) - (SensorValue[motorrightbottoms]);
		lasterror = error;
		if (error == 0)
			derivative = 0;
		if(error <= integralactivezone && error != 0)
		else
			integralRaw = 0;
		moveforward(finalpower);
		wait1Msec(40);
		if(error <= inchToTicks(.5))
			timerBool = false;
	moveforward(0);
	wait1Msec(100);
	clearTimer(T1);
task autonomous()
	motor[motorleftbottom] = 0;
	motor[motorrightbottom] = 0;
	motor[motorlaunch2] = 127;
	wait1Msec(1455);
	PIDforward(56,0.99);
	PIDforward(-56,0.9);
	PIDturn(90, 0.89);
	PIDforward(38,0.99);
	motor[motorintake] = 127;
	wait1Msec(4000);
	wait1Msec(1455);
	PIDforward(-62,0.99);
	// Insert user code here.
	// Remove this function call once you have "real" code.
	AutonomousCodePlaceholderForTesting();
Does at least the proportion part work
One thing I noticed is that you are not using while loops. Your code will run through the loop once, and then be finished after it waits 25ms.
I put a while loop with a timerbool in it
the timerbool runs until it is false
the timerbool is false if the error is <= .5 inches
is it ok ???
