RobotC Sensor Program
I would like someone to check my program for any errors and if it seems like it should work.
task autonomous()
resetSensor(LeftEncoder);
resetSensor(RightEncoder);
SensorValue[LeftEncoder] = 0;
SensorValue[RightEncoder] =0;
while (1 == 1)
if(SensorValue[LeftEncoder] == SensorValue[RightEncoder])
motor(leftwheels) = 127;
motor(rightwheels) = 127;
if(SensorValue[LeftEncoder] > SensorValue[RightEncoder])
motor(leftwheels) = 100;
motor(rightwheels) = 100;
else
motor(leftwheels) = 0;
motor(rightwheels) = 0;
I can give my motor and sensor setup if needed.
It looks like there is some assistance for you in this thread.
https://vexforum.com/t/response-to-robotc-sensor-program/38507/1
A few more comments.
resetSensor and SensorValue] = 0 do the same thing, resetSensor is the natural language equivalent of setting the value to 0.
Most of the time there will be small differences between the encoder counts, you should use a tolerance value here, something like “if the difference between the encoders is less than 10 drive straight”
As Doug said, once you have given a motor a value of 90 or over the increase in power is minimal.
You need a couple more else statements, two of you tests are the same but set the wheel speeds the opposite way. Here is a revised version with the changes I described.
task autonomous()
  SensorValue[RightEncoder] = 0;
  // This will drive forwards for the entire 15 second auton period
  while (1 == 1)
    // The assumption is that both encoders count up when motors are running forward
    if( abs( SensorValue[LeftEncoder] - SensorValue[RightEncoder]) < 10 )
      // Both motors the same speed
    else
      // Left running too fast
      motor(leftwheels)  = 80;
    else
      // right running too fast
      motor(rightwheels) = 80;
