RobotC White Text
Where you would usually have a function’s name the text would be white, making it blend in with the background. I have Tried restarting my computer and reinstalled the program though nothing is changing. I am Using the newest update of 4.55 and it has became a new problem.
That sounds like the text color was changed, you can go to the detailed preferences, select the editor tab, then fonts and reset all colors to their defaults. You could also delete all registry values from the view menu, either way should reset colors back to their default values.
