i need help with code making a arcade drive with four motor on the right analog stick.:eek:
Something like this (not tested or compiled), motor_left_1 etc. should be defined in motors and sensors setup.
#define JOY_DRIVE_V vexJSRightV
#define JOY_DRIVE_H vexJSRightH
void arcade_drive()
int ctl_v;
int ctl_h;
int drive_l;
int drive_r;
ctl_v = vexRT JOY_DRIVE_V ];
ctl_h = vexRT JOY_DRIVE_H ];
// Create drive for left and right motors
drive_l = (ctl_v + ctl_h) / 2;
drive_r = (ctl_v - ctl_h) / 2;
motor motor_left_1 ] = drive_l;
motor motor_left_2 ] = drive_l;
motor motor_right_1 ] = drive_r;
motor motor_right_2 ] = drive_r;
could u break it down and help me??
Here I am defining the two joystick axis I want to use
vexJSRightV is the same as Ch2
vexJSRightH is the same as Ch1
I’m doing this so if I decided to change to the left stick it’s easy to find, you could skip if you want and just use Ch1 and Ch2 in the code.
Some variables to make the code easier to read
int ctl_v;
int ctl_h;
int drive_l;
int drive_r;
Get the values of the vertical and horizontal joystick and save in two variables
This is the classic arcade drive algorithm, you could skip the divide by 2 for a faster drive. store the result in two variables, one for the left motors and one for the right.
Send the left drive value to the two left motors
Send the right drive value to the two right motors
This code is deliberately long, it could be shortened to perhaps 4 lines but I thought it would be easier to understand this way.
what would the one in four lines look like?
motor motor_left_1 ] = (vexRT vexJSRightV ] + vexRT vexJSRightH ]) / 2;
motor motor_left_2 ] = (vexRT vexJSRightV ] + vexRT vexJSRightH ]) / 2;
motor motor_right_1 ] = (vexRT vexJSRightV ] - vexRT vexJSRightH ]) / 2;
motor motor_right_2 ] = (vexRT vexJSRightV ] - vexRT vexJSRightH ]) / 2;
just so i can understand it can u break it down?
do u also know how to program a four motor drive with a holonomic drive all on the right joy stick?
You can’t really, while still taking full advantage of the holo drive. One joystick is needed to control forward/back/side-side motion, while the other would be needed to control spin. (At least, that’s the way I see it)
//Andrew
i figured it out
Will you tell how?
//Andrew
well you have to have a seprate joystick for the strafe.
Ok, thanks!
//Andrew
