RobotMesh Two Controllers
Hi, everyone
I meet a problem in using two controllers to control one robot. In Robotmesh, I select two controllers with the Partner controller. But, when I test the controller, only one controller works, can anyone provide me some opinions?
Thanks,
Gator Robotics
Are the two controllers connected together? You need that for partner joysticks i believe.
How should I program on the Robotmesh?
Which language - Python, Blockly, C++, JavaScript? Also, is this for V5 or Cortex?
Hi, I am now using Blockly and V5
I just tested it and everything’s working normally for me. How are you trying to use it? Would you mind sharing your code by setting the project to public (through the Options gear at the top right) and sharing a link to it?
