Rookie Team Code Fail
Hi. We are a rookie team and we are going to a competition tomorrow. We waited until the last minute to do our code and we do not understand why it does not work. We basically tried to code it so that the arm would lift up and down, but when it hit the top, a bumper switch would prevent it from moving up further. The arm can go down, but it won’t go up regardless of whether the bumper switch was hit. When we comment out the bumper switch part of the code the arm moves fine. Help would be greatly appreciated. Our code is attached below.
#pragma config(Sensor, dgtl1, topBumper, sensorTouch)
#pragma config(Motor, port1, frontLeftDrive, tmotorVex393TurboSpeed_HBridge, openLoop)
#pragma config(Motor, port2, clawdump, tmotorVex393TurboSpeed_MC29, openLoop)
#pragma config(Motor, port3, farleftDump, tmotorVex393TurboSpeed_MC29, openLoop)
#pragma config(Motor, port4, leftInDump, tmotorVex393TurboSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port5, rightTopDump, tmotorVex393TurboSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port6, rightBottomDump, tmotorVex393TurboSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port7, rightInDump, tmotorVex393TurboSpeed_MC29, openLoop)
#pragma config(Motor, port8, backLeftDrive, tmotorVex393TurboSpeed_MC29, openLoop)
#pragma config(Motor, port9, frontRightDrive, tmotorVex393TurboSpeed_MC29, openLoop, reversed)
#pragma config(Motor, port10, backRightDrive, tmotorVex393TurboSpeed_HBridge, openLoop)
#pragma platform(VEX2)
// Select Download method as “competition”
//Main competition background code…do not modify!
#include “Vex_Competition_Includes.c”
void pre_auton()
task autonomous()
task usercontrol()
while (true)
motor[backLeftDrive] = motor[frontLeftDrive] = vexRT[Ch3] + vexRT[Ch1]; //drive left
motor[backRightDrive] = motor[frontRightDrive] = vexRT[Ch3] - vexRT[Ch1]; //drive right
if(getJoystickValue(Btn5D) == true)
motor[clawdump]= 60;
else if (getJoystickValue(Btn5U) == true)
motor[clawdump] = -60;
else
motor[clawdump] = 0;
if(getJoystickValue(Btn6U) == 1 && SensorValue(topBumper) == 0)
motor[farleftDump] = motor[leftInDump] = motor[rightBottomDump]
= motor[rightTopDump] = motor[rightInDump]= -100;
else if(getJoystickValue(Btn6D) == 1)
motor[farleftDump] = motor[leftInDump] = motor[rightBottomDump]//revive dump
= motor[rightTopDump] = motor[rightInDump]= 100;
else
motor[farleftDump]= motor[leftInDump] = motor[rightBottomDump]//kill dump
= motor[rightTopDump] = motor[rightInDump]= 0;
I don’t see any issues with the code (assuming motor power -100 makes the arm go up), I tried it on a test system and it seems to work. Perhaps you have a bad switch or extension cable, look at the sensors debug window and make sure the switch can change the sensor value between 0 and 1. You could also try using another digital input in case dgtl1 is damaged for some reason.
