There is a little issue with my rubber banding on my lift, where i can’t add a lot of rubber bands or else my claw can’t pick up the bottom cube, but i need more rubber bands to lift up three cubes. Please help ASAP
You just made a thread about this.
The solution is making the bands have a lesser change in tension, however you want to do that. many dr4bs use triangle banding but it’s up to you.
If the change in tension is too great, the lift becomes limited in moving range
