It looks like the GDC has chosen to update SC1, possibly in response to some Q&A entries.
Original SC1 Text
All scoring statuses are evaluated after the Match ends, once all Scored Blocks, Field Elements, and Robots on the Field come to rest.
a. This rule’s intent is for Driver inputs and Robot motion to cease at the end of the Match, when the Match timer reaches 0:00. A pre-programmed routine which causes Robot motion to continue after the end of the Match would violate the spirit of this rule. Any Scoring which takes place after the Match due to Robots continuing to move will not count.
Updated rule
All Scoring statuses are evaluated after the Match ends, once all Scored Blocks, Field Elements, and Robots on the Field come to rest.
b. Any Scoring into Goals which happens after the Match, even if Robots have stopped moving, will result in that Goal being considered “empty”. All Blocks in the Goal will receive zero points, and the Goal will not receive any points for a Uniform Bonus. The Goal will not have reached any Fill Level, therefore no Height Bonus will be awarded.
Violation Notes: A Team’s first instance of Scoring a Block after the end of the Match will be considered a Minor Violation. Subsequent Violations will be recorded as Major Violations and Disqualifications.
Is anybody else struggling with the new wording here? It appears they took a mildly murky situation and muddied it all up. a. and b. seem completely incongruous with each other, and b. is in direct conflict with the main body of the rule. Scores are tallied after all objects come to rest, but also objects that happened to be moving at 0:00 could also result in an ascending series of Violations? A literal interpretation of this rule suggests that a block that was falling into the goal at 0:00, which previously would have been perfectly legal, now empties the entire goal and possibly DQs a team. Are we now penalizing teams because gravity exists, and is uncontrollable?
It is also not clear if the goal is emptied for all teams on the field, or if the (presumably innocent) alliance partner would get credit for the blocks in the goal as ruled in Q1697.
Furthermore, no guidance is given with respect to teams making a last-ditch effort to Park or Partially Park their Robots. I would err on the side of giving the benefit of the doubt to the team, unless it’s very obvious the Driver continued to control the Robot after 0:00. But this interpretation would be in direct conflict with SC1b. and the violation notes.
Help me figure out what the GDC’s intention is with these updates, and how we can call matches in the future in a way that is fair, sustainable, and supportive to children just trying to do the best they can.
If I was King of GDC, this is what I would write:
All Scoring statuses are evaluated after the Match ends, once all Blocks, Field Elements, and Robots on the field come to a natural rest.
a. This rule’s intent is for Driver inputs and Robot motion to cease at the end of the Match, when the Match timer reaches 0:00. A pre-programmed routine which causes Robot motion after the end of the Match would violate the spirit of this rule. Any Scoring which takes place due to Robot motions initiated by Driver input or pre-programmed routines will be removed from the count for the entire alliance, and the offending team may be subject to a Minor or Major Violation and a Disqualification if repeated or egregious.
