Inner green delrin blocks because from personal experience the outer ones pop off the slide in high torque applications. Just make sure to use some type of grease with the inner ones.
We tried using the outer slides on our scissor lift during toss up… The slides would pop off every couple minutes. I do not recommend using the outers.
I don’t have any actual experience with the outer bracket blocks because we only used the inserts, but according to others I would say that there are no negatives and all positives to using the inserts, and not the brackets.
