What material do you need to make a scissor lift ?
Hi 7035,
The VEX Engineering team cannot provide guidance on your design. As such, this question isn’t well suited to the “official tech support” section of the forum.
I’ve moved your thread into the Technical Discussion forum where you can get help from the VEX community!
Good luck with your design.
You can Google vexforum.com scissor lift and look through the search results. But here are just a few threads to help get you started poking around:
https://vexforum.com/t/scissor-lift-calculations/26338/1
https://vexforum.com/t/how-can-we-make-this-scissor-lift-better/27098/1
https://vexforum.com/t/scissor-lifts-best-type-and-parts/26632/1
Hope that helps.
