Scoring the barrels
Hey, does anyone know if the barrels get stuck if you drop them in horizontally as opposed to vertically?
Thanks,
RobolovR
They dont get stuck, as far as i can remember, there is no way for the barrel(or ball) to get stuck in the goal unless 2 objects are forced in.
The barrels are 5" tall. So if something that’s 6" wide can fall through, then something that’s 5" wide will have no problem.
  • Sunny G.
i think if i remember correctly the goals are about 10’‘-12’’ wide, and have 2-ish inch thick pvc pipe. so if its if you subtract the 4 (2 pieces of pvc (one on each side)) pieces of of pvc you get 8’'. that leaves roughly 2 inches of free space, they fit no problem!
barrels on their own are fine, but we’ve had a few instances in NZ so far wherein a barrel and ball (with ball seated inside the curve of the barrel) have dropped together and fallen sideways, preventing further scoring in the goal. Purely unintended.
