Here’s a simple example showing how to use the VCS SD card save and load file API. This saves some information into a file called “test.h” on the SD card and then reads it back again.
#include "robot-config.h"
// storage for some information to save
uint8_t myTestData[ 100 ];
uint8_t myReadBuffer[ 1000 ];
int main() {
// set the test data to something detectable
for(int i=0;i<100;i++) {
myTestData* = i * 2;
// write test data to SD Card
int nWritten = Brain.SDcard.savefile( "test.h", myTestData, sizeof(myTestData) );
// did that work ?
if( nWritten > 0) {
// display on screen how many bytes we wrote
Brain.Screen.setCursor( 2, 2 );
Brain.Screen.print( "We wrote %d bytes to the SD Card", nWritten );
// now read it back into a different buffer
int nRead = Brain.SDcard.loadfile( "test.h", myReadBuffer, sizeof(myReadBuffer) );
// display on screen how many bytes we read
Brain.Screen.setCursor( 3, 2 );
Brain.Screen.print( "We read %d bytes from the SD Card", nRead );
// and display some of the data
Brain.Screen.setCursor( 6, 2 );
for(int i=0;i<8;i++)
Brain.Screen.print("%02X ", myReadBuffer*);
else {
Brain.Screen.printAt( 10, 40, "Error writing to the SD Card" );
In addition to this, the standard C API can be used, code like this (just a snippet, will not compile)
// Test C file API
FILE *fp;
printf("read VEX_Messages.h\r\n");
fp = fopen( "VEX_Messages.h", "rb" );
if( fp != NULL ) {
fseek( fp, 0, SEEK_END );
int len = ftell( fp );
fseek( fp, 0, SEEK_SET );
printf("that worked, size is %d\r\n", len);
if( len > 0 && len < 128000 ) {
char *buf = (char *)malloc( len );
int nRead = fread( buf, 1, len, fp );
printf("we read %d bytes\r\n", nRead );
free(buf);
fclose(fp);
else {
perror("could not open file");
printf("\r");
Also, under certain conditions C++ streams can be used but we have found some issues with VCS in this area so I would avoid that for now.**
