Selling VEX EDR Mechatronics Kit
Below is a list of components included in the kit; it has been used for about 6 months and includes storage containers based on category (one for metal, one for programming and sensors, etc.)
Includes:
Curriculum & Manuals
(1) Quick Start Guide, Clawbot
Logic
(1) VEX ARM® Cortex®-based Microcontroller
(1) USB A-A Tether Cable
(4) Motor Controller 29
Structure
(8) Bar, 25-hole
(2) Bar, 20-hole
(2) Chassis Bumper (25-hole)
(2) Chassis Bumper (20-hole)
(4) Chassis Rail (25-hole)
(4) Chassis Rail (16-hole)
(4) C-Channel, 1x2x1x15 hole
(1) C-Channel, 1x2x1x20 hole
(2) C-Channel, 1x2x1x25 holes
(2) C-Channel, 1x5x1x25 holes
(2) Plate 5x5 holes
(2) Plate 5x15 holes
(2) Plate 5x25 holes
(2) Angle, Slotted 30 holes
(2) Angle, Slotted 30 holes Inverse
(2) Angle, Segmented 25 holes
(4) Gusset, Pivot
(4) Gusset, Angle
(4) Gusset, Plus
(1) Hinge (2-pack)
(1) Latex Tubing (10’)
(1) Rubber Band (20-pack)
(10) Standoff 0.50"
(8) Standoff 1.00"
(4) Standoff 2.00"
(4) Standoff 3.00"
(102) Screw, 8-32 x .0375" Long
(42) Screw, 8-32 x 0.500" Long
(28) Screw 8-32 x 0.625" Long
(14) Screw 8-32 x 0.750" Long
(3) Screw, 8-32 x 1.500" Long
(10) Screw 6-32 x 0.250" Long
(10) Screw 6-32 x 0.500" Long
(6) Locking Screw, 6-32 x 0.250" Long
(6) Locking Screw, 6-32 x 0.500" Long
(172) Nut, 8-32 Keps
(28) Nut, Nylock 8-32
(30) Washer, Steel
(10) Washer, Teflon
(82) Bearing Attachment Rivet
(26) Shaft Spacer, Thin (4.6mm)
(20) Shaft Spacer, Thick (8mm)
(25) 4" Zip Ties
Sensors
(1) Bumper Switch (2-Pack)
(1) Limit Switch (2-Pack)
Motion
(5) 2-Wire Motor 393
(1) Claw Kit Assembly (includes motor)
(4) Shaft Coupler
(37) Shaft Collar
(12) Shaft, 3" Long
(4) Shaft 11mm long
(4) Shaft 2" long
(2) Shaft 4" long
(4) Shaft 12" long
(44) Bearing Flat
(6) Bearing, Pillow Block
(4) Lock Plate, Plastic
(6) Spur Gear, 12-tooth
(4) Spur Gear, 36 tooth
(10) Spur Gear, 60-tooth
(4) Spur Gear, 84-tooth
(20) Rack Gear, 19-tooth
(4) High Strength 12-tooth Gear
(4) High Strength 36-tooth Gear
(4) High Strength 60-tooth Gear
(16) High Strength Square Gear Insert
(16) Free Spinning Gear Insert
(4) Intake Roller (8-pack)
(1) 2.75" Wheel (4-pack)
(1) 4" Wheel (4-pack)
(1) 4" Omni-Directional Wheel (2-pack)
(25) Tank Tread Traction links
(30) Conveyor-belt Base links
(10) Short Conveyor-belt inserts
(10) Medium Conveyor-belt inserts
(10) Tall Conveyor-belt inserts
(4) High Strength 6-tooth Sprocket
(2) High Strength 12-tooth Sprocket
(2) High Strength 18-tooth Sprocket
(2) High Strength 24-tooth Sprocket
(2) High Strength 30-tooth Sprocket
(280) High Strength Chain Links
(40) Chain Attachment Links
(2) 12" Long Linear Slide Track
(2) 17.5" Long Linear Slide Track
(2) Rack Bracket
(4) Inner Acetal Slide Truck
(4) Outer Acetal Slide Truck
Control
(1) VEXnet Joystick
(2) VEXnet Key 2.0
(2) Cable, 3-Wire “Y”
(2) Cable, 3-Wire Extension, 6"
(2) Cable, 3-Wire Extension, 12"
(1) Cable, 3-Wire Extension, 24"
(1) Cable, 3-Wire Extension, 36"
Power
(1) 7.2V Robot Battery NiMH 3000mAh
(1) AAA NiMH Rechargeable Battery 6-pack
(1) Smart Charger v2 w/ Power Cord Options
(1) 8-Bay AA/AAA Smart Battery Charger
(1) VEXnet Backup Battery Holder
Equipment
(2) Tool, Hex Key (5/64")
(2) Tool, Hex Key (3/32")
(2) Tool, VEX Open-Ended Wrench
The VEX website prices this at $899 + tax and s&h.
I will be selling it for $500 + s&h. DM me for more inquiries or reply to this message.
I’ve edited the original post to remove personal contact information. Please exchange this info through DM
