Sensor Help!
////________________________________________________________________________________________________________
//above is the code for the wheels which allows wheels to move in a 350 degrees rotation.
if(vexRT[Btn7U] == 1)       	//If button 7U is pressed...
	motor[armMotor] = 127;    	//...raise the arm.
else if(vexRT[Btn7D] == 1)  	//Else, if button 7D is pressed...
	motor[armMotor] = -127;   	//...lower the arm.
else                      		//Else (neither button is pressed)...
	motor[armMotor] = 0;      	//...stop the arm.
//////______________________________________________________________________________________________________
//above is the code for the arm which allows it to move up and down
// Open, close or do not more claw
if(vexRT[Btn6U] == 1)       	//If Button 6U is pressed...
	motor[clawMotor] = 127;  		//...close the gripper.
else if(vexRT[Btn6D] == 1)  	//Else, if button 6D is pressed...
	motor[clawMotor] = -127; 		//...open the gripper.
	motor[clawMotor] = 0;    		//...stop the gripper.
////_______________________________________________________________________________________________________________
//above is the code for the claw allowing it to open and close
if(vexRT[Btn7L] ==1)			//If button 7L is pressed
	motor[beltMotor] = 127;  		//Move the Conveyor belt forward
else if(vexRT[Btn7R] == 1)  	//Else, if button 7R is pressed...
	motor[beltMotor] = -127; 		//Move the Conveyer belt backwards.
	motor[beltMotor] = 0;    		//...stop the Belt.
//above is the code for the conveyor belt allowing it to move back and forth
if(vexRT[Btn8R] ==1)			//If button 8R is pressed
	motor[rotationMotor] = 63;  		//Rotates the claw
else if(vexRT[Btn8L] == 1)  	//Else, if button 8L is pressed...
	motor[rotationMotor] = -63; 		//Move the Conveyer belt backwards.
	motor[rotationMotor] = 0;    		//Dont rotate
if(vexRT[Btn8D] ==1)
wait1Msec(2000); // The program waits for 2000 milliseconds before continuing.
int threshold = 505;      /* found by taking a reading on both DARK and LIGHT    */
/* surfaces, adding them together, then dividing by 2. */
while(true)
	// RIGHT sensor sees dark:
if(SensorValue(lineFollowerRIGHT) > 505)
	// counter-steer right:
	motor[frontLeft]  = 63;
	motor[frontRight] = 0;
	// CENTER sensor sees dark:
	if(SensorValue(lineFollowerCENTER) > 505)
		// go straight
		motor[frontRight] = 63;
	// LEFT sensor sees dark:
	if(SensorValue(lineFollowerLEFT) > 505)
		// counter-steer left:
		motor[frontLeft]  = 0;
		motor[frontLeft] = 0;    		//Dont rotate
:grinning: Thanks for any help given.:belarus:
