I’m fairly new to sensors and basically with this years game sensors seem to be the most efficient way to use your 15 autonomous period. I’ve been reading up on the sensors, but can’t really grasp what each sensor can do fully. Can anyone describe each sensor and what they can do as well as the application use.
The ROBOTC wiki has a pretty good overview, obviously the example code is ROBOTC specific. Are you an EasyC or ROBOTC user?
http://www.robotc.net/wiki/VEX2_Sensors_Overview
If you are using ROBOTC, then I also gave some explanation on how to go about debugging code using sensors in this post.
I’ll be using ROBOTC as of right now, but I am in the learning stages right now
Well what kind of sensors did you want to learn more about?
