Can I change the angle of a servo motor. I am using one with the signal splitter to control steering and I want to increase the lock (decrease the turning circle). Increasing the servo angle 10 or 20 degrees would be the easiest way. Otherwise I may use a longer crank. I do not intend to change the gears in the servo motor. The servo has the identification of simply “Vex Servo Motor”. It is about 5 years old. Thanks!
The servo is limited by the hardware. If you give the command set motor clockwise or counter-clockwise those are the full extents of the servo travel.
Thanks for the quick reply kingo… I will try a longer crank.
