Hello again. sorry if this is a repeated question, but i wanted to know if there was a command that would allow the servo to be set to a different position upon startup but at the same time will not interfere with the button control to set the servo to a different postion. heres my code, and it works well. but i want to add in the feature i described.
#pragma config(Sensor, in1, , sensorReflection)
#pragma config(Sensor, in2, , sensorPotentiometer)
#pragma config(Sensor, dgtl1, , sensorLEDtoVCC)
#pragma config(Sensor, dgtl2, , sensorLEDtoVCC)
#pragma config(Motor, port1, , tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port2, , tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port3, , tmotorVex393_MC29, openLoop)
#pragma config(Motor, port4, , tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, , tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port8, , tmotorServoStandard, openLoop)
#pragma config(Motor, port9, , tmotorVexFlashlight, openLoop, reversed)
#pragma config(Motor, port10, , tmotorVex393_HBridge, openLoop, reversed)
task flash2;
task headlight;
task headlight()
while(true)
if(SensorValue[in1] > 400)
motor[port9] = 127;
else
motor[port9] = 0;
if(vexRT[Btn5D] == 1)
motor[port8] = -127;
else if(vexRT[Btn5U] == 1)
motor[port8] = 127;
if(vexRT[Btn8U] == 1)
motor[port5] = 63;
else if(vexRT[Btn8D] == 1)
motor[port5] = -63;
else
motor[port5] = 0;
if(vexRT[Btn6U] == 1)
motor[port4] = 21;
else if(vexRT[Btn6D] == 1)
motor[port4] = -21;
else
motor[port4] = 0;
task flash2()
while(true)
if(SensorValue[in2] > 30)
SensorValue[dgtl1] = true;
wait1Msec(500);
SensorValue[dgtl1] = false;
wait1Msec(500);
else
task main()
startTask(flash2);
startTask(headlight);
while(1==1)
motor[port1] = (vexRT[Ch1] + vexRT[Ch2])/2; // (y + x)/2
motor[port10] = (vexRT[Ch1] - vexRT[Ch2])/2; // (y - x)/2
motor[port2] = (vexRT[Ch4]);
motor[port3] = (vexRT[Ch4]);
if(vexRT[Ch1] || vexRT[Ch2] == 0)
SensorValue[dgtl2] = false;
else
SensorValue[dgtl2] = true;
you see, i have a servo controlling the potentiometer. but when i start up the robot, it resets the servo to 0 before i press the two postion toggles. what id like is for the servo to match up with the position of:
upon startup, but i dont know if any code that could be used to do such would interfere with the entire setup of:
motor[port8] = 127;
please reply if you can help me with this
