Hey Everyone! So I’m having an issue right now where I’m trying to use the position of the smart motor to set a zero point and when I call it I would like it to go the distance and after the distance is near met then go back to the zero point. This is for a lift and I have some code I thought would work but you cannot assign it to the expression.
void liftautofunctions(float x){
Lift2.position(rotationUnits::rev = x);
