I was told by a previous team mate that one of the commands for motor spinning was better to use but I forgot, any help would be nice!
Thanks!
You can use setVelocity to calibrate the motor speed with the controller joysticks. I’m sure there are other ways of doing this though. I think spin and spinFor are mostly for autonomous.
if you are programming using C++ (or Python for that matter) avoid setVelocity completely.
use spin when just wanting the motor to spin at a given velocity and spinFor/spinTo when asking the motor to spin on its own to a requested position (number of rotations etc.)
vex::controller Controller;
vex::motor m1(PORT1);
void usercontrol( void ) {
while (true) {
m1.spin( forward, Controller.Axis1.position(), percent );
this_thread::sleep_for(10);
Will this only let the motor go forwards? Or will the fact that it’s using a controller axis let it also rotate backwards.
The motor will be able to go forwards and backwards.
Using m1.spin(forward… with a negative value will run the motor in reverse. Controller.Axis1.position() will give values between +100 and -100, the best way to learn about this is to experiment and see what happens.
setVelocity()
alone does nothing. All it does is set the default velocity of the motor for whenspin
is eventually called.spin
will spin a motor at a desired speed. For examplemotor.spin(vex::forward);
will spin the motor forwards at whatever speed you set it to usingsetVelocity
beforehand.spin
will run the motor continuously untilstop
is called at a later time.- You can also explicitly give
spin
a velocity to run at, for examplemotor.spin(vex::forward, 100, vex::percent);
- spinFor is primarily for autonomous routes. It’ll spin the motor for either a certain time period or certain amount of rotations.
- Unlike
spin
, spinFor will automatically stop the motor once it’s reached the target, meaning you don’t have to callstop
. spinFor
is a blocking function, meaning that you can’t do anything else while the motor is spinning. The motor has to complete the spin for any future code to run.
- Unlike
Example (spins the motor at 50% velocity for one second):
// Option A (using setVelocity)
motor.setVelocity(50, vex::percent);
// Option B (passing velocity straight to spin)
motor.spin(vex::forward, 50, vex::percent);
// Wait a second
vex::wait(1, vex::seconds);
// Stop the motor after a second
motor.stop();
Equivalent code using a blocking spinFor
(notice there is no vex::wait
or motor.stop()
motor.spinFor(1, vex::seconds, 100, vex::percent);
Well almost, if the motor is already spinning then setVelocity will change the motor’s velocity.
more thoughts I have on setVelocity here.
Also quick clarification to add to some of the weirdness. There’s no overloaded version of spinFor
that accepts vex::percentUnits
, but there IS one that specifically accepts vex::velocityUnits
. This is different from spin
that accepts both types.
Therefore this:
motor.spinFor(1, vex::seconds, 100, vex::pct);
would throw a compiler error, but this:
motor.spinFor(1, vex::seconds, 100, vex::velocityUnits::pct);
would not. The example from my previous post does not compile
